Hello all,
Hoping you guys can help a guy figure out where he went wrong. I have a standard 12 V plug in the back of my 4runner that I've been using to run my fridge over the summer. However, the fridge plug has a tendency to dislodge, and cause the fridge to have a fault.
Anyway, as I got the fridge back in May, I went ahead and got the new ARB 12 volt harness for the fridges, thinking I had one of the new plugs. Anyway, when I got the harness, I found that it is not a simple plug and play as I had thought. Here is my issue:
The top photo is the arb harness, the bottom is my fridge plug. They do not fit together. The ARB fridge plug is larger than the harness socket, by a good bit.
I either ordered the wrong harness, and need a new one, or I need to order the new fridge cord, as I have the older fridge cord. I would like to end up with the most current harness and fridge cord as they are supposed to make better connections than the old ones.
Thanks!
Thanks!
