LMTV 4x4 expo build
aernan
Truck Specs:​
  • M1078 LMTV (Light Medium Tactical Vehicle) (14,515kg GVWR / 225hp)
  • Engine: Caterpillar 3116 ATAAC - 6.6 liter inline 6 turbo / aftercooled diesel
  • Transmission: Allison MD3070PT automatic 7-speed
  • Axles: Meritor axles with 5.39 gear ratios
  • Transfer Case: Allison Fixed ratio
  • Differential Lockers: Center lock 30%/70% split
  • Wheelbase: 157.5 inches (4000mm)
  • Cab: Standard military cab
  • Winch: Frame mounted hydraulic winch, either front or rear deploy 12k
  • Tires: Standard are 395/85R20 military radials.
Camper design:
  • All aluminum construction
  • Fully welded structural frame
  • non thermal bridging walls
  • glued and riveted skins
  • 4 point spring pedestal attachment
  • spray foam insulation 100% fill
  • Tern Overland
    • Door
    • Windows (2x)
How does one have no thermal bridging with "glued and riveted" panels?
Looking forward to see where this goes!
Truck Specs:​
I have one coming in a few months but frp composite panels and welded perimter angle
Truck Specs:​
Nice I have this build coming up on a BAE. 24' frp composite pod with welded angle exo cage with complete interior build out
Kevin
2eleven
