LoD Bumper Rattle
BCobe
Does anyone on here have an LoD Rear bumper? I recently installed mine and it has started to rattle a lot. Went through an re tightened all of the bolts but still get some rattle.
I have the full length that is not connected to the rear door.
Comanche Scott
Tailgate stop adjustment
You may need to adjust the door striker stop bracket to eliminate play between the latch and the jamb.
Below is a picture.
I used a pencil to mark the original location. Then with the tailgate shut, pushed in to see how much it moved. Then moved the stop bracket to eliminate that movement.
If you look closely at the picture you can see the pencil mark where it was originally about 1/8" behind the striker stop bracket.
Since there is a rubber bumper bolted to the tail gate which sits against the tire carrier back plate, any looseness in the tailgate will cause a rattle sound over bumps, as the tire carrier moves separate of the body (since the bumper is attached to the frame of the Jeep, not the body).
Hope this helps,
rubicon91
So a few of us have them on here. After mine was installed a few years ago about 3 weeks later I had this rattle off the drivers side in the rear. Couldnt for the life of me figure it out. Come to find out a bolt was rubbing on that side. Had it trimmed up and not an issue since outside of me not shutting the latch totally and the tire swing coming around on my old Jeep and hitting the side as I left the car wash. As long as you latch the tire carrier you will not have that problem:sombrero:
BCobe
Below is a picture.
Hope this helps,
I will have to look int this. Thanks for the info!
Was it a bolt on the Jeep or on the bumper. Have looked around and haven't found or seen any signs of rubbing. I took the tire carrier off, drove around and not squeak. Put the tirecarrier on without the tire and no squeak. Tire back on = squeak. The rim is as back as far as it can go. I think it might be the tire itself squeaking, if thats a thing, since it only happens when I hit pot holes.
what model? They have the new destroyer series as well as a few others.
I have the full length signature series with the tire carrier not attached to the Jeep.
jlbstock65
I just had LoD full length rear bumper that is not attached to the door installed this week and am going on a trip that will total 7-800 miles next week. I sure hope I don't have any issues. So far I love the looks and it seems very rugged. Just having to go without the trail basket as it was backordered.
BCobe
I would be sure to take some tools with you or ensure that everything is good and tight before you go. I had thread locked the majority of my bolts and still had some loose ones. The contact area were the swing touches the latching area has also had some rubbing.
SilicaRich
Wandering Inverted
Below is a picture.
That's what I need to adjust on my ARB carrier. It's never been properly adjusted and rattles and squeaks all over the place
rubicon91
Was it a bolt on the Jeep or on the bumper. Have looked around and haven't found or seen any signs of rubbing. I took the tire carrier off, drove around and not squeak. Put the tirecarrier on without the tire and no squeak. Tire back on = squeak. The rim is as back as far as it can go. I think it might be the tire itself squeaking, if thats a thing, since it only happens when I hit pot holes..
Sorry for the delay. My issue was with a bolt on the bumper not the tire carrier. I will tell you I had to adjust the tire carrier when I put it on my new jeep so I could tighten down my spare tire. The level it was set at on my old Jeep was not going to work with the new stock rubicon tires. Not sure if that could be an issue for you or not. Outside of that 1 bolt I have had zero issues with mine for the few years I have owned it. Good Luck!
BCobe
Adjusted the door a bit and only get a rattle when I hit pot holes. Haven't taken it offroad yet so that will be the true test
BCobe
Idk if anyone is interested but I ended up moving my tire to the bolt holes at the bottom of my tire carrier. Zero rattles or squeaks now.
dterrell
