The arm on the lever shaft can be flipped to make it work backwards. Here are a couple of correct arrangments. It varies with the gearbox and in most cases, you can get it to work reversed.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
