voodoo2crue
Hi all, my name is Craig and about a month ago I bought an Ltt-f chassis trailer 2006 model. it's pretty much a copy of the M1101/02 without the box. The plan is to build a wood box camper with a sleeping quarters and a rear galley. So far progress has been slow and will continue to be if I have anything to do with it lol. So far I've removed the channel and decking, added a 7 prong plug and installed 12volt LED trailer lights. I've got hubs on the way so I can match my FJ bolt pattern. I also weighed it after stripping the deck its 1020lbs. The hummer wheels weigh in at 165lbs each so I estimate it should weigh about 850 once the wheels are replaced. It's a pretty heavy starting point but i'll work with what I got for now. Future may see a timbren axle with electric brakes but for now I'm going to see how it works out. The plan now is to keep things simple, build the structure out of 3/4 plywood and epoxy fiberglass it to help keep it all together and protected and then paint or bedliner. I'm also planning a simple 3/4 inch framework to the interior walls so I can put some foam board insulation and then finish it off with a 1/4 or 1/8 plywood. This will also give me an easy way to run the wiring. Any ideas, concerns are welcome as I'm new to this and certainly have a lot to learn.
