I'll just leave these here......
These are from this project....
http://www.chaosfab.com/projects/blazer/blazer.html
I'm a firm believer in using the big tire little lift system. While I agree that you will have some work to do in the axle department....it isn't anything a set of 4.56 geared M1008 CUCV axles wouldn't fix! Bolt in fun with a rear Detroit ( and a set of recentered H1 rims would carry the theme really well )
You might contact the builder above. It doesn't look like they cut the rear very much at all. With the right backspacing and tire position in the wheel opening its surprising sometimes how much tire you can fit. In the front I wouldn't be afraid to cut it, its all replaceable. I would think REALLY hard about using a set of 'glass front fenders with more room. You will have to do something for the inner fender if you want to keep the engine clean....but that old diesel doesn't care that much.
Good luck. Finding a used 37" tire and a rim to bolt up is worth every penny. That will tell you for sure what needs to be done....
Great info and thanks for the link. This is what I'm looking at as I am reading this post. The lift is based on 6" but maybe I need to rethink the fender cutting and see how that would pan out.
http://www.trailworthyfab.com/home.php
(5) 8 Bolt Hummer Wheel Special w/
Goodyear Wrangler radials 37x12.50x16.5 - Hummer Tire
http://www.offroaddesign.com/
1. Weld-in Frame Repair kit
GU39002 $80
2. Dana 60 Crossover Steering and High Steer Kits {$800}
Pitman arm
Part #:70203 $70
Steering arms:
RH Arm Part #: U9001
RH Arm Price: $150.00
LH Arm Part #: U9003
LH Arm Price: $150.00
(2) Stud kit part #: U9002
Stud kit price: $30.00 (set of 4 ARP high strength, 190,000 psi studs)
Draglink:
Tube part #: U9015
Tube price: $95.00
(2) Ends for draglink and tie rod #:U9016 $95 per pair
High Steer Tierod:
Tube part #: U9014-High Steer
Tube Price: $85.00
3. Lift System {$2015}
http://offroaddesign.com/catalog/6inchliftsystem.htm
Front lift springs:
6” EZ-Ride Front Tuff Country Springs $350
Front U-Bolts:
1 Ton (Dana 60 Front Axle) U-Bolt Kit #GU37051 $48
Heavy Duty Greasable Front Shackles GU37011 $99
Greasable Spring Main Eye kit GU37012 $27
Brakelines:
79-98 and D60, 10mm Brake line kit through 6” Lift GU30011 $112
Sway Bar Disconnect Kit GU37001 $99
Swaybar bushings:
Sway Bar Bushings 81-87 BG05003 $19
Bolt-in steering box brace:
81-87 GU39001-L $130
Rear Lift:
4” Shackle Flip '73-'87 ('91) GM #GU38010 $189
3" Rear Tuff Country Lift Spring $456
Greasable Suspension Components:
Greasable Rear Spring Bushing Kit 1 ½” Spring Eyes and 1 ½” Shackles #GU38002 $90
Rear U-bolts:
¾ and 1 Ton Rear U-Bolt Kit TCI-17752 $40
Bilstein 5125 Shocks set of 4 $356
4 pcs BE5-A465-H7
ORD High Clearance HD Engine Crossmember $189
Part #:GU32005-Big Block
Fits '73-'87 GMs with big block or diesel motor
PSC Steering Kit $1083/$379
Steering Box SG041MR
Steering Pump SP1405
Remote Reservoir Kit SR102K
Steering Cylinder Kit 2" SC2202k
Hose Kit HK2022
Cooler kit DER-13212
14 Bolt Full Float Disc Brake Bracket Kit $150
http//offroaddesign.com/catalog/14FFdisckit.htm
Brake rotors from a '73-'87 GM 3/4T front axle. (Napa) $90
Calipers from a '73-'87 1/2 or 3/4T front. (Napa) $20
