M101CDN Trailer mods
PCRover
I was planning on a 12V pump to get the water out of either setup. Tanks I have found are anywhere from $90-$190 depending on the size and shape and manufacturer. I am willing to go up to $200 for a good sized tank if that is what it costs. I figure $300 for a tank and pump is a good investment to have 20-30 gallons of water available at the throw of a switch.
Good idea about making the tank (and pump if used) removable to allow full bed usage. I took some inside measurements today and will surfing for tanks that might fit tonight.
ChuckB
This might be a dumb question, but I'm still a noob so I'm going to have to ask it for my own edification (and hopeful some others :sport_box )
When you guys are talking about water storage in tanks like this, is this drinking water or water for showers, dishes or all of the above??
PCRover
It could be for everything. My plan is to use it for just about everything (shower, cooking, cleaning, etc) but probably not drinking.
BajaXplorer
MY answer would be the same as PCRover. We carry plenty of drinking water in the truck, but the water in the tank would have to be drinkable as well.
BX
lowenbrau
PCRover said:
How did the weekend trailer towing go?
Sorry for the slow reply, I havn't been around. The trailer tows well, probably more stable than stock. The tires can catch trees a bit on uber tight trails but that was managable. Thankfully the trail was a bit drier this time.
Mudy_Ovl
PCRover,
If you haven't found a water tank yet check out www.plastic-mart.com and click on their RV Water tanks. 30Gal (39"x15"x12.5") would fit nicely across the trailer bed. And at $155.00, it is much cheaper than www.watertanks.com. Then you can pick up a 12VDC 2.8 gpm Shurflo water pump for $59.00. Add a little bit for connectors and hosing and you have a great water system for around $250.00 that is removable when you don't need it.
Chris D.
DFWSFO
