M105A2 Question
jagular7
Bella PSD said:
Yes,
The 105 weighs 2,600 lbs empty!
The 101 weights about 1,200 lbs. empty (I think??)
Louie
Close and it depends on the mfr and yr. I had both a M105 and a M101A1back in early Y2K. My old M105 weighed 2750#s empty. My old M101A1 weighed 1375#s empty. I actually just purchased another M101 through gov't sales but it'll be a few more weeks as they have to do research on the End Use Certificate I had to fill out.
You may want to rethink about the M101. Tires are 36" tall. The drum brakes are massive and probably weigh 90#s each themselves. The axle tube also is hefty. The box itself is rather large also. It should be 4.5' x 6.5'. I suggest you replace the axle and tires with something with less weight and rolling mass.
Cruiser
If you swap out the axle to a 3500# with jeep sized wheels, drop the huge landing leg roller thing you will drop some serious weight. I was looking at one to use the frame as a start point for a smaller box that would resemble a m416, just longer with a tailgate. Just haven't found one for the right price near me..
Big Daddy Chia
thos ideas sound good. when the auction starts i'll bid on it. Also whats the deal with pintl hitches. some one said u cant driv faster then 15mph on the road with them
roadkill
I've had my M416 with stock pintle hitch up to 75-80mph on the road. the only issue you'll have with a pintle is noise and a little added feedback at lower speeds on rough terrain from the slop in the hitch. at highway speeds I couldn't tell any difference between the pintle and a ball hitch.
roadkill
probably a good idea to swap springs too. you'll loose some weight and have a better riding trailer as you won't be carrying as much weight as it was designed for. no need for 1 ton springs on a compact truck.
jagular7
That is what I did with my rolling M101 frame.
End result of a boat tongue, Dexter 3500# axle, sprung under axle, new car tires (should have gotten trailer tires), and some old Ford rims with '0' offset. I kept the stock springs.
I've drilled the frame to relocate the axle 20" in 5" segments depending on the weight of the camper and tongue requirement. Once I finalize weight distribution, I'll be adding shocks.
jagular7
Found a picture of my old M105 from back in winter 01. It held a cord of wood with no problems.
Thats a Dodge Grand Caravan behind it.
RRDirtyHarry
i just picked me up one. pulling it with my 90 jeep Cherokee. gonna pick up a m101 later for offroad use. just cant find one near me.
Mcoleman
