XKTX85
I've gotten a lot of ideas from this site and decided I'd try to give back by sharing my build experience.
In December I purchased a M116a3 flatbed military generator trailer for $600 off a guy on Facebook. My daughter and I drove 3 hours to get it and bring it home. That same month I purchased a welder....both sat for 7 months while I tried to decide exactly what I wanted to do.
Initial assessment of the trailer: solid platform to build on, more ground clearance than my Jeep, easy to register in Georgia as a homemade. Cons...previous owner used cheap bed liner to coat the underside (all of it including bolts, grease points, wires), plus leaf springs will need to be replaced. The surge brakes are questionable at best, but it rolls and for the price I'm happy.
I've decided to use the Xventure trailer as the example I'm starting with:
The "right choice" for where to start is probably the suspension, frame restoration, or switching to electric brakes....but I want to get out and start using this on trips with my daughter so I'm gonna build the top half first.
I've broken this into 3 phases:
Phase 1: Goal 22 oct
•Jockey Wheel
• Build a subframe
• skin the trailer
• install hatches for the galley/kitchen
• remove old lights, broken jack stand
• raptor line the deck
• paint the skin
Phase 2: GoalAPR 23
• convert to electric brakes (surge brake removal will loose pintle hitch and add articulating hitch
• build pullout kitchen
• fabricate slide for cooler/fridge
• build/fab bed cover
• install 12v power system (100ah+ battery, shore power, charge from tow vehicle, set up for future solar)
•lights
• build swingout spare tire carrier
Phase 3: GoalJuly 23
•fab bed rack
• Add rooftop tent
• install 20gallon water tank, pump system
• Propane water heater
• add fridge/freezer
• add solar panels
• fab 270° awning
• new leaf springs
• swap out Wheel tires for something lighter
****CURRENT PICTURE AS OF 13AUG23****
Phase 1: Goa
• Build a subframe
• skin the trailer
• paint the skin
Phase 2: Goal
Phase 3: Goal
• Add rooftop tent
• add solar panels
• fab 270° awning
• new leaf springs
