Jeepcrz said:I am about complete with my M416 lid build. I'll try to take a photo in the next day or so. I'll try to explain what I did. I purchased 1"x1" steel square tubing I think it was 16 gauge (thick enough to drill and tap a 1/4 28 screw) and I screwed it tightly up against the bottom surface of the round tube that goes around the perimeter of the tub. I used seven 1/4 28 screws, I drilled and tapped, then I put 4 hinges each 3" tall by 4" long and drilled and tapped into the 1"x1" tubing under the tube lip and then drilled holes thru for the lid.
I'll get pictures by Saturday morning of what I did.
Jeepcrz
