TheRedDawn
Maranda V-165 Slide-In Camper Shell Designed for a Toyota Tacoma (Similar to Spacekap and Tufport shells)
This is a simple, efficient, and practical design for a sweet camping experience or a mobile workstation/truck. (I used it for both)
Details - Weight - 435 pounds
Height - 68"
Bed Length - 78"
Total Length - 111"
Bed Width at Back - 51"
Door Width - 39"
Door Height - 57"
Volume - 165 cf
Inside Height - 68"
External Width by Wheels - Clears your Tacoma wheel wells.
More details -
Locks from the inside and outside
Roof vent installed - No leaks.
I kept it simple when camping with two pieces of carpeted plywood across the inside on three pieces of 2x6. Internal length is a little over 6' when set up like this.
Side Brackets - I carried some long surfboards with these.
If you want to add some windows, it's a simple project.
And more details -
This is designed and fits perfectly in a Tacoma long bed. I also had it on a 5 ft bed Tacoma with minor mods. The four brackets are designed for the standard Tacoma bed rails I had on both our 2006 and 2009 models. I assume this design extends for more years.
The scratches on the passenger side top look a little worse than they are. I spread out some silicone in case water could get under the scratches. What you're seeing is dirt embedded in the silicone.
Depending on your camping style, this could be the most epic camper you're ever seen. Need a toilet and plumbing? This isn't the camper for you.
Extras - Bed Slide 1000 CL + $400
Rieco Titan Camper Jacks with extension plates + $400
Located in Grass Valley, CA. 95945 (about an hour from Tahoe or Sac)
$1,995.00 - Cash only.
I will not drive to meet you anywhere.
No trades.
Questions? lmk.
Thank you,
Matt
Height - 68"
Bed Length - 78"
Total Length - 111"
Door Width - 39"
Door Height - 57"
Volume - 165 cf
Inside Height - 68"
More details -
And more details -
No trades.
Questions? lmk.
Thank you,
Matt
