Material for fresh water tank
Duraweld, the place I got the custom tank from also sells some premade tanks (rotomolded). They had a pretty good selection and I will likely order the gray water tank from them as it is a simple cube.
I bought 2
Hey guys, one of the issues with getting a generic sized tank is my habitat design and where I want to place the tank. If you look at the front wall you will see a small angle there. That is in place to allow the cab to flip up and get the box as close to the cab as possible. Seemed like a good idea at the time but has added a lot of work compared to a regular box. Anyway, in order to get the maximum amount of water for the available space the bottom front edge of the tank will have to match that angle and then go vvertical.A
I needed 4-120g tanks for my build. Two for freshwater and one each for the grey and black water.
Roto tanks for RVs are thin while roto tanks for boats are heavier.
I bought one 3/8"-1/2" marine PE roto tank for test fitting. Glad I did because the manufacturer's drawing didn't show the cross ribs on the bottom. Ribs are OK for a black tank in a boat that is pumped but not a RV tank that gravity drains.
Shipping the tank back was going to cost $300 so I bought 1 more to use for FW then had custom tanks made for the black and grey. These were made with 3/8" HDPE and the bottom sloped 1/4" per foot in 2 directions to a 3" drain fitting in one (side) corner. The bottom and sides of these tanks were welded inside and out and the top was welded on the outside. The metal support frame was made to fit the bottom of the tank.
The FW tanks with no slope were installed in a flat frame over the axles with beveled insulation at a 1/4" per foot slope to 3/4" fittings in the (bottom) corner. Side fittings in FW tanks do not drain all the water...or the sediment .... from what I've seen this is a good place for things to grow.
All the tanks have stainless rotary nozzles for flushing.
As mentioned the tanks are support by metal frame. A steel frame on 4 sides with a bolted aluminum plate supporting the bottom. The tanks are removed from the bottom. Inside the frame there is 2" Formular 200 insulation and 3" heat ducts controlled with valves so warm air only blows at the tanks when the thermometers located at the bottom of the tanks show heat is needed.
I had the 3" drain fitting installed in the custom tanks but I wasn't sure where the rest of the fittings would go. After test fitting I used a 3hp router along with aluminum mandrels that I made to spin weld the fittings.
Another issue was the tank level guage. I started with a SeeLevel system only to discover the "moda technology" is erratic on material over 1/4". Ended up switching to an iSeries from TechEdge Mfg. They put the moda sensor inside 3/4" PVC pipe that screwed into the top of the tank.
The TechEdge system can be customized for 6 tanks including 2 - 90ohm inputs for fuel/propane while the tanks on SeeLevel panels are preset. Both are really good systems.
ELShockley
