Mercedes Benz online parts database access
sprocket3
Does anyone know how to get access to accurate build details and parts from a VIN. I think there was an EPC page, but i'm not sure it's it's open still. I've been looking at truck and it's really hard to figure out the gears and specs from listings.
Thanks
MogsAndDogs
Howdy. I think you have to find someone with access to the EPC and they can enter the VIN.
what kind of truck is it?
sprocket3
I've been doing that and it's a bit of a drag. Looking at a lot of SK/AK trucks the last six months. Do those EPC CDs on ebay provide anything?
sprocket3
I use this, the link will probably leas you to my vehicle, but use the back-links at the too.
I think these show all specs and parts. Which doesn't tell me what axle ratios that a certain truck was built with. This site shows an automatic for a truck that is a manual.
The experts are able to get this data somehow. I think they have EPC access.
VIN code : WDB9520731K329382
AL3 Vorderachse 7,5 t
AM3 Hinterachse H7 13,0 t Tellerrad 300
AP6 Achsübersetzung i = 4,143 (HL7)
B02 Bremsanlage, Antiblockiersystem (ABS)
BB6 Trommelbremse an VA und HA
C95 Wegfall Heckunterfahrschutz (EG)
CL9 Lenkung LS 6/LS 8
EC6 Anhängersteckdose 15-polig
EC7 Anhängersteckdose 12 V, 13-polig
ED5 Parametrierbares Sondermodul (PSM)
ER3 MB-Radio Sound 4024
ET1 Spannungswandler 24/12V, 8A
EV1 Vorrüstung Bündelfunk 12V
F05 Fahrerhaus M (mittellang)
F34 Fahrerhausrückwand ohne Fenster
FE5 Fensterheber elektrisch, Fahrer- und Beifahrertür
FL4 Komfortfahrerhauslagerung vorn (1,8 HZ)
FS9 Außenspiegel, elektrisch, Fahrerseite
FZ7 Wegfahrsperre, mit Transponder
GC3 Getriebe G 210-16/14,2-0,83
GS3 Getriebeschaltung "hydraulisch"
GV1 Verteilergetriebe VG1700 - 3W, 2-Gang
I72 Reifen schlauchlos, 315/80 R 22,5 VA/NLA
I73 Reifen schlauchlos, 315/80 R 22,5 HA
IA1 Radformel 4x4
IB5 BAUREIHE SKN-V TP"B"
IB7 Baureihe SKN-V
IC2 Kipperfahrgestell
ID1 Blattfederung
IL2 Export-Code
IQ5 Radstand 3900 mm
IV0 18,0-Tonner
J10 Tachometer km
J70 Drucklufthorn
K40 Tankschloss
KH7 Auspufftopf, Endrohr seitlich nach außen
KS2 Haupttank 300 l, Stahl
L16 Nebelscheinwerfer, Halogen
L26 Zusatzscheinwerfer
MD9 Tempomat
MK1 Geschwindigkeitsbegrenzer elektronisch, 104 km/h
MX1 Motor, V6, LA, 230 kW (313 PS), 1800/min
NC1 Doppel-NA MB 125-11b/2c, Flansch+MPA, M-Drehzahl
NZ2 Nebenabtrieb, doppelt
Q18 Schlussquerträger, geschraubt
QC6 Vorderfeder, 7,5 t, hart
QE9 Hinterfeder, 13,0 t, hart
R04 Radmutternabdeckung
R38 Steilschulterfelgen 9,00 x 22,5
R60 Reserveradhalter, provisorisch
SG6 Komfortpaket Fahrerschwingsitz, "Isringhausen"
TM1 Gewichtsvariante 19,0 t (7,5/13,0)
X57 Geräuschmaßnahmen, EG 96/20
Y28 2 Unterlegkeile
Y33 Aufpumphilfe, Steilschulterfelgen
Z91 Export-Lieferumfang
353U feuerrot
I think there’s a way to enter your VIN
Correction: not possible to enter VIN.
However, for example in my case, once I selected the correct model (405.230 = U500, North America homologation), and the correct engine designation ((906.912), when I then went to “engine electrics”, then “alternator” (or “generator”), it correctly gave me 2 choices: 145a and 270a versions.
At that point I had to actually remember (or look on my original build sheet that came with the vehicle) that I had the 270a version, to get the correct part number. Just an example, since I replaced it with a Delco 28si years ago.
Sophia Lopez
