Mission overland
flipmachine
Hi guys... I am building a bigger unit for this family so they have asked me to put this one forsale...
My wife and I purchased the 2019 Summit Series from Mark last summer, and had one of
the most amazing adventure filled summers of our lives. We’ve owned similar ‘tear drop’
style trailers in the past w/ a roof top tent, but I became frustrated with having to sleep
separately from my wife and two kids. Not to mention the roof top tent took me away from
the heated luxury of the trailer interior on those cold mountain nights! This trailer provides all
the basic luxuries (on demand hot water, shower, running water sink, 30-gallon fresh water
storage, dual burner stove, heater, insulated walls, KIDS BUNK, 2000W inverter, dual 12V
batteries, ample storage, propane mount, and much much more!) to give your family the
ultimate camping experience. On those rainy days there is a drop down table inside which
converts to a bed in the evenings.
The unit fits in our single car garage and provides us with the ability to hitch up and go
camping immediately after work on Friday. The is approximately 3,500 lbs GVWR and a crb
weight of 2,250 lbs, which means most mid-sized SUV’s can easily haul this trailer. One of
the unique items this trail offers, is that is fully insulated with a propane furnace! This means
your camping season has just been extended to 4 seasons!
This unit is specifically designed for travelers with young kids. When the trailer is ‘popped’
there is two retractable panels with room for two kids to sleep. I have a 4-year-old and a 2-
year-old and they absolutely loved sleeping up top. We were able to sneak in 50 nights with
this unit and have no complaints. When the top is popper there is roof to stand up to 6’3”
which, in my opinion, is a massive advantage over traditional tear drop trailers.
We are selling this trailer to be the first to purchase Mission Overland’s larger unit for some
additional space for our two pets and some of the newer features they are offering. If you
are wondering what “Kiwetinok” means, it is Cree for “On the North side”.
Please see below for trailer specifications:
 MODEL INCLUDES STANDARD HSS TUBING STEEL WELDED FRAME SANDBLASTED AND
PRIMED 2 COATS BLACK ENDURA
 WELDED TUBING FRAMED FENDERS WITH 1/8 CHECKERPLATE ALUMINUM FENDER AND
STEPS
 3500 LB TIMBREN OFF ROAD INDEPENDENT AXLES WITH DEXTER HUBS AND BRAKES, 6
ON 5.5" BOLT PATTERN
 BFG TA KO2 255/75R17
 2" HEIGHT ADJUSTABLE COUPLER
 DOT COMPLIANT LED MARKER LIGHTS AND REFLECTORS WITH 7 PIN MOULDED
CONNECTOR
 1.5" 16 GAUGE ALUMINUM WALLS INNER AND OUTER WITH HIGH DENSITY FOAM
INSULATION TO R12
 2 STARBOARD CUPBOARD DOORS WITH SOUTHCO LATCHES ALUMINUM FRAMED AND
1/8"" ALUMINUM SHEETED ROOF HIGH DENSITY FOAM INSULATED TO R7
 1/8" STANDARD VVIVID 3M VINYL WRAP
 BULLDOG SOCKET WELDED TONGUE JACK 90 DEGREE STOWABLE
 2 INTERIOR LED LIGHTS, 2 EXTERIOR LED LIGHTS
 2 INTERIOR USB CHARGING SOCKETS AND 1 110V OUTLET
 2 REAR CABINETS THAT GO FROM THE ROOF TO THE FLOOR,"48" IN HEIGHT".
 36" HEIGHT X 26" DEPTH X 52" WIDTH STEEL HEAVY DUTY MULTI PURPOSE TOP CHEST
(24" X 24" DFK ON BOTH ENDS), BLACK POWDERCOAT FINISH
 DYNAMIC POWER PACKAGE STAGE 2 INCLUDES 2 X 12 VDC DEEP CYCLE BATTERY IN
FRONT MOUNTED TONGUE BOX, BLUE SEA FUSED POWER DISTRIBUTION BLOCK, BLUE
SEA BATTERY DISCONNECT, MARINE LIT ROCKER SWITCH PANEL WITH BUILT IN RELAYS,
DUAL USB CHARGER WITH LED VOLTAGE DISPLAY
 PROPANE PACKAGE POWERTANK ALUMINUM MOUNTING BRACKET ON DRIVERS SIDE
REAR WITH 10LB PROPANE BOTTLE
 30 GALLON 10" DEEP HARDENDED POLY WATER TANK,
 2 DOMETIC 24" SIDE WINDOWS, EACH CONTAIN PRIVACY SCREEN AND BUG SCREEN
 5 LPM ECOTEMP L5 ON DEMAND HOT WATER PACKAGE IN STEEL BOX POWDER COATED
WITH SHOWER
 SMEV 2 BURNER STAINLESS COOKTOP WITH IGNITER AND GLASS FOLDING COVER
 CUSTOM FABRICATED CANVAS ROOF THAT OPENS TO 6'4", WINDOWS ON EACH SIDE,
WHICH INCLUDES BUG MESH, AND RAIN GUARD,
 SINK PACKAGE SMEV RECT STAINLESS STEEL W/34MM F/H 14" X 16" X 4" FOLDING
GLASS LID AC542 FOLDING FAUCET SUREFLO 12 VDC WATER PUMP 2.4 GPM
 DOMETIC INTEGRATED 65 QUART 12 VOLT FRIDGE ON 32" HEAVY DUTY SLIDE
 2000W INVERTER
I am leaving the sale in Mark’s capable hands to manage and have the unit stored at his shop
until delivery terms and finalized. I believe Mark is working to have these in dealerships in the
new year and are retailing for $33 - $35 K. This is a great deal for a family looking for endless
adventures!
flipmachine
different trailer but gives you an idea...as for rating... its meant for kids, I had put both my kids up there 12 and 7 and no flex at all.
WFOORBUST
Is there a way to add a screen to the rear door? How much bigger is the newer model trailer that you are building for them?
JSKepler
