Good day. This is my first post.
I currently own a Nissan Patrol GU2 TB48de
![12984067_978840358836150_5456424215609849046_o.jpg 12984067_978840358836150_5456424215609849046_o.jpg](https://expeditionportal.com/forum/data/attachments/383/383579-68388cd96c7992af445a5db72064764c.jpg)
I'm planning to switch to a Canter FG
But this is the only FG that is forsale in the Philippines where I live.
OPTION 1
The Brand New option
http://mitsubishi-bestdeal.ph/canter-fg-83/
Will this be a good starting point?
GENERAL SPECIFICATIONS DIMENSIONS
Wheelbase(mm)3460
Overall Length(mm)6120
Overall Width(mm)2035
Overall Height (approx.)(mm)2435
Tread (Front/Rear)(mm)1665/1560Min.
Ground Clearance, approx.(mm)210
Cab to Rear Axle (C.A.)(mm)2920
Cab to End Frame (C.E.)(mm)4395
Frame Width(mm)750Front
Overhang(mm)1130Rear
Overhang(mm)1475
Seating Capacity(persons)3
WEIGHT
Curb Weight(kg)2470
Payload(kg)3030Max.
Gross Vehicle Weight(kg)5500
CALCULATED PERFORMANCE
Max. Speed(km/h)91
Max. Gradeability(tan?) %48
Min. Turning Radius(m)6.8
ENGINE
Model 4D34-2AT5
Type 3.9 L Stroke Cycle, Water-Cooled Turbocharged and Intercooled Direct Injection Diesel
No. of Cylinders 4 In-Line
Piston Displacement (cc) 3908
Bore x Stroke (mm) 104 x 115
Max. Power (PS/rpm) 110/2900
Max. Torque (N-m/rpm) 275/1600
Air Cleaner Dry Paper Element Type
Fuel Tank Capacity (L) 100
DRIVELINE
Clutch Type Single Dry Plate
Spring Type Diaphragm Spring
Control Hydraulic-Controlled
Transmission Type 5 forward, 1 reverse M/T
2nd-5h Synchromesh, 1st and Reverse Constantmesh
Gear Ratio 1st 5.380
2nd 3.028
3rd 1.700
4th 1.000
5th 0.722
Reverse 5.380
Final 6.166
Transfer Gear Ratio Model 2-Speed Constantmesh
High 1.090
Low 1.987
Final Reduction Gear Front Single Reduction, Hypoid Gear (D1H)
Rear Single Reduction, Hypoid Gear (D033H)
OPTION 2
USED IMPORTS
There are other imported trucks from Japan that are also available but not an easy to catch.
https://www.olx.ph/item/mitsubishi-...esel-manual-4x4-90k-ID7XvBX.html?h=98ac97c3c3
Like this Mitsubishi Canter Double Cab 4D30 Engine
![1540746999136.png 1540746999136.png](https://expeditionportal.com/forum/data/attachments/383/383569-b90c19fd0de84a210edf22c0c4621284.jpg)
Mitsubishi canter (blue color)
https://www.olx.ph/item/2018-mitsub...-and-mit-canter-4x4-ID8oz7c.html?h=98ac97c3c3
Doublecab
4M40 diesel engine
Brandnew dashboard
All original
Good running condition
Registered in manila
2018 year model
![1540747332892.png 1540747332892.png](https://expeditionportal.com/forum/data/attachments/383/383575-4a7a18aa73b56dfcaff3350ccd21da1c.jpg)
Here in the Philippines, I have not seen an offroad or expedition enthusiast that used these light commercial trucks. Only used by vegetable haulers from mountain provinces.
Thank you in advance.
OPTION 1
![fg83.jpg](http://mitsubishi-bestdeal.ph/wp-content/uploads/2015/04/fg83.jpg)
Wheelbase(mm)3460
Overhang(mm)1475
WEIGHT
Curb Weight(kg)2470
Payload(kg)3030Max.
Max. Speed(km/h)91
ENGINE
Model 4D34-2AT5
DRIVELINE
2nd 3.028
3rd 1.700
4th 1.000
5th 0.722
Reverse 5.380
Final 6.166
High 1.090
Low 1.987
OPTION 2
USED IMPORTS
Doublecab
4M40 diesel engine
Brandnew dashboard
All original
2018 year model
