MJ build
flyn2er
Bought this March of 09, had been sitting for almost 3 years.
Left it sit for another year while i worked on the wifes XJ. Finally got started with a "used, ran good when i pulled it" motor.
Swapped in some Dakota seats, build a center console and some bumpers and i was ready for the road. :)
Ran the guts out of it for the following year with big plans to come...Leaf sprung front end.
Picked up a Rodeo 44 w/4.10's and a wagonner 44 that i had to regear.
This is the ride height i'm looking for...
Work got crazy and the MJ got put on the back burner again till recently :)
Started welding up a bumper to hang the springs on.
Semi-finished bumper
flyn2er
Got the front crossmember cut but left 1" attached and beefing it up a little with some 1"x1"angle. Waiting on my son to come over and help me get this thing back in place. hopefully by the weekend. :)
Logans91XJ
Dirt Road Anthem
I always wanted and still want an MJ.... But finding one in decent shape and the owner not wanting a million dollars for it is another challenge in its own!
flyn2er
Why are you wanting leafs in the front?
The biggest reason is money...money is tight. Second biggest reason is less moving parts to worry with and ride can be adjusted by removing or adding leaves. I have right around 300.00 lifting it 6-7 inches.
flyn2er
Decided to cut notches in the bumper to keep the hi-lift from slipping.
Finish welding it up tomorrow night, paint saturday then bolted back on sunday.
maddmaxjack67
Looking good amigo! Are you using the waggy leaves for the front? I have some wagoneer donor axles laying in my backyard and I was considering doing leaf sprung in the front to keep it simple as well.
flyn2er
Thanks for all the comments everyone. Yes im using stock waggy springs. They need adjusted because they put the jeep to high. I'm 5-11 and they put the hood at armpit height.
I'm also using UBE's in the rear so that would bring the back up to 6.5".
flyn2er
Got the winch in and bumper reinstalled. Next step is to get the topper back on and see how to set it up for camping.
Sfreeman
