Modified 2003 Land Rover Discovery 2 SE, Black on Black, Lifted and Locked, w/ CDL!
speedpin
Sold sold sold
$10200
Disco is in great shape, is built for the trail but is also suited as a daily driver.
Mechanically sound, regular maintenance and upkeep as needed.
Fluids serviced, front/rear diffs, Transfer case, Engine Oil,
Just rolled over 90K miles
Passed VA inspection last month with no issue
Everything works, No dash lights
AC/Heat work great, heated seats, heated windshield and mirrors
Traction Control and Hill Decent
No sunroofs, so none to leak
Many modifications completed by Randy at RoverBones
3rd owner
TRANSFER CASE HAS CENTER DIFF LOCK CDL, I believe its out of an 2004, works great
3 inch Terrafirma lift
Terrafirma shocks
HD steering linkage with 4 new HD Tie Rod Ends
New OME steering Damper
Full ARB Bumper with fog/parking lights
9K Warn Winch with New Viking Synthetic Line
Rock Sliders with Step
Rear recovery Bumper
Hitch and Hitch wiring kit
Weld on RoverBones Diff Guards
Safety Device Roof Rack with new flooring
Safety Device rear ladder
LED roof lights and backup lighting
Hella spot lights
HID headlight Kit
5 285/75/16 Kenda Mud Terrains, 80% tread remaining
Powdercoated S wheels
Full size matching Spare with aftermarket tubular spare tire mount
New Cobra CB mounted w/ rear 4' Firestick antenna
Currently has Front (TrueTrac) and rear (Detroit) lockers with GBR 4:11 gears, Also comes with factory open diffs complete drop in third members
HD Ashcroft Axles, also comes with factory axles
New front double cordon driveshaft
Rebuilt rear u joint style driveshaft, also comes with rebuilt factory shaft
Flip out DVD, NAV, CD, MP3 head unit, Can watch DVDs anytime
Exterior is in great shape, has a few scratches/dings due to age and use, small dent behind driver rear wheel
Interior is in Excellent condition, Black leather, Rubber cargo matt, Very Clean
Comes with two keys, remote lock and unlock work
Clean and clear title
Located in Fredericksburg VA
Trailer not included
May consider defender trades w cash
Apaden
Have the head gaskets been done? And have your checked into the oil pump failure that is known for the 03's?
speedpin
The head gaskets have not been replaced but not having any issue. Randy at rover bones did replace the oil pump components and replace front cover seal. Also new plugs and heavy-duty plug wires less than 1k miles ago
flipstick
