Mohawk Dave's 2004 Sequoia - Athena
Mohawk Dave
A documentation of my build.
I will copy the way Sal R. does a write up as I think it is excellent (some of it is copied and pasted because I could not word it better. Thanks Sal!). I doubt I'll go into as much detail per post, but I am happy to answer any questions if possible.
GOAL:
My goal for this weekend warrior/dog carrier is centered around exploring/camping trips. Jack of all trades type of PreLander.
Exploring to me is lots of off-road, but I've also done a lot of on-road adventures and it is fun when you're with good people (i.e. going to Pikes Peak to race, but stopping at MTB parks and fishing spots)ergo, I want this thing to have good road manners. Because of her size, tucked and low slung were a requirement. I did not want to unnecessarily add width and height unless it served a real purpose. (err...width might be coming soon)
MODIFICATIONS:
Suspension
  • Front: I guess it's 2" Lift ???
    • King Coilovers, 2.5" with 800 lb VST springs, with finned clicker remote reservoirs (I snagged the reses off one of our pre-runners that was getting upgraded)
    • Valving 20 over 20 with 15 single in Reservoir
    • ODR uniball upper control arms with heims at chasis
    • Total Chaos Double shear thing for upper bolt.
    • (me) OEM upper bolt delete, cut and sleeved with threaded tube, now 9/16" bolt from each side.
    • Total Chaos polyurethane steering rack bushings
    • Total Chaos gusseted spindle
    • (me) Lower 1.25" uniball conversion
    • (me) Modified OEM lower control arm for 3/4" uniball bolt, bushing delete and uniballs at chasis
    • (me) Heim steering using Camburg Clevis
    • (me) Swaybar quick disconnect
  • Rear: 1" of 2" Lift ???
    • ARB 2862 Old Man Emu Coil Springs
    • King 3.0 bypass with reservoirs (one off...my buddy worked at King and made them on his "lunch break")
    • (me) lower links with heims at axle housing, bushing at chasis
    • (me) panhard bar, heimed at both ends
Drivetrain
  • 5.29 Nitro / Yukon Gears (not installed yet)
  • Harrop E locker F/R (not installed yet)
  • Master Flow MF-1050 air compressor (ported and polished. lol)
Wheels & Tires
  • BFG 35 x 12.5 x 17 All Terrains (was on 285s)
  • Spidertrax 1.25" spacers WHS007
  • GX460 Big Brakes
  • Mil-Spec F/R sleeved and stainless steel brakelines
  • Cheapo tire deflators
Exterior
  • Off road Custom Design roof rack (powdercoated OD Green)
  • Tubbed Firewall
  • (me) Gas Tank skidplate
  • (me) Rock sliders
  • BD Squadron Pros in lower bumper
  • Knockoff BD Squadrons at ditch lights
  • Rago Fab Ditch Light Brackets
  • Amazon cheapy 32" light bar in lower bumper (nilight or whatever)
  • Pelican Storm iM3220 Case (x3) on roof rack (1. chairs etc, 2. blankets and Emerg. Clothing, 3. Recovery) Just lightweight stuff.
  • Smittybilt side awning
Interior
  • Atoto A6 Pro Android Unit, dual bluetooth with OBD2 reader for Torque Pro
  • Off road Custom Design MOLLE panels at rear windows (modified with extra mount plus D-Rings, PC'd Gold)
  • 4" foam mattress, Canvass cover bolted to floor via rivnuts
  • RAM mount for Tablet
  • (me) phone and GPS mounts at dash
  • (me) Cargo net thing to keep dogs out of front seats
  • (me) "dog run" at ceiling that their lanyards clip into and then to their harness
  • (me) Rear hatch MOLLE panel
  • (me) flat stock with D-Rings at grab handles
  • Plano All Weather tactical gun case - 36" = Toolbox (low COG)
  • ICECO VL45 Refrigerator w/ Slide & Cover
  • Some rearview backup camera
  • LED dome light bulbs (so worth 10 bucks)
  • Front Runner Footwell Water Tank (10.6g) w/ 1/2 air hose and Amflo water spout
Recovery
  • Cheapo traction boards
  • Some kinetic rope thing
  • HMMWV scissor jack (modified to take ratchet extension)
Safety & Comms
  • Kenwood TK-790 remote head
  • Samsung 10" tablet on RAM mount, running GAIA
  • Bao Feng Handhelds
Miscellaneous
  • Tabs to hold front side markers in fender
  • Derale 13212 power steering cooler
  • Land Cruiser snorkel with modified tubing etc
  • All Weather Pack connectors with Mil-Spec paired wiring
Future
  • Maybe LT if I get ambitious, with a single side 3 link
  • F150 supplemental fuel tank
  • BFF F/R bumpers
  • 12k winch (sitting on the shelf)
  • Cage it
Photo is just my album cover.
Mohawk Dave
Here is the LCA uniball Conversion. 1.25" Uniballs with a 3/4" NAS bolt. I bought a 2-5/8 annular cutter. We welded "wedges" onto the knuckle as seen. Then drilled, sleeved, and bored out steering side of knuckle to run through bolt with heim steering.
Mohawk Dave
Firewall Tub. Trimmed fenders and flares as well. 35s clear at full bump/full lock.
Mohawk Dave
Rock Sliders I 2x4x.120 & 2x2x.120 with 2x3 angle at frame. Powdercoated OD Green, then ground and weld where needed.
Mohawk Dave
Gas Tank Skid Plate I fabbed - 3/16" plate, 2" C Channel, tabs. Skid Row plates on the front half.
Mohawk Dave
Lower Links and Panhard I built. PC'd OD Green. I offset the bushings on the links for "rock slideability".
Mohawk Dave
Front Runner Footwell Water Tank. 10.6 gallons. Non-pressurized. I used Mil-Spec B32 lever activate buckles. mainly for dog water, washing dishes, extinguishing camp fire etc....shower will have to be something else???
Cvonruex
