Montero Sevice Manual wheels tires
Monterorider
Garage cleaning.
Set of OEM Gen 3 20th anniversary addition alloys 16x7. Very nice shape $200
IMHO better looking than other OEM style wheels available. Here is what they look like with some 33"s on Gen 3
Gen 3 2001 Shop service manual 4vol SOLD. Not a collectors item but nothing else get job done.
Gen 3 2002 Owners Manual $5
Set of older Eagle 149 alloys with tires. $100 16x8 +2mm offset (about 4.5") backspacing 6x139 lugs. No nuts. Should fit most 6 lug vehicles like Toyota, Mitsu, Nissan, Isuzu, etc. Good wheels in poor cosmetic shape. Original powder coating is pealing.
Tires are 285/75R16 - 33" tall. 3 of those are Yokohama MT. Lost 4th to piece of angle iron in Nevada. 1 fairly new maybe 70-80% tread. 2 others less so 25-30%. One of the later one had a thorn stuck in sidewall patched up holds air fine. 4th Tire I picked up for lack of better alternative at the time is Toyo AT with usable tread.
1 OEM Gen 2 Montero wheel with tire. Looks like new just a bit dusty still has original Yokohama AT. 15x7 +10 offset. 31x10.50R15. Tire looks new but it's got to be 20 years old. Might not be roadworthy. $50
I can ship on buyers dime. Although wheel with tires wouldn't make sense IMHO.
Center bore is way to small. Offset is way too much. Gen 3 has +46 offset (about 5.5" backspacing) that would push wheel way too far into wheel well. I've had second set of 33" MTs on those. Saves expensive tires and saves gas riding stock size for DD. Really pays for those larger tires in a year or two maybe. It's like getting free tires.
Say if you drive 15k a year at 15 mpg you would need 1000gal of gas ~ $4000. Ride stock tires for say 16.5-17 average you need only 900 or less 100 gal $400 savings let alone more comfortable ride better braking etc
Wolfbox
