MORryde Driver Side Jerry Can Mount for Jeep Wrangler JL or Gladiator JT
Jeepskate
Rugged, powder-coated steel. Really well made. Used, but in excellent condition. Local pickup only in southern NH. Could arrange to meet in Nashua or Manchester area.
Sells for $180-$195 online (with no Jerry Can). Yours here for $100 (also with no Jerry Can). Comes with mount, tray and hardware to mount to Jeep Wrangler JL (2018+). Will not work with Jeep Wrangler JK. Will not work with the Wrangler 4xe plug-in hybrid, as it would block the charge port. I believe this also works with the Gladiator JT, but you will need to confirm.
My pictures show it holding a 5-gallon Wavian Jerry Can we used for extra fuel. It fit perfectly. NOTE: Sale does NOT include the Jerry Can. You will need to supply your own can. I have read that it works with NATO, Wavian, Sceptre, or Rotopax, Gas or Water Containers - it may work with others as well. For Rotopax containers, you would use only the mount, and not the tray. The Rotopax configuration would require a separate Rotopax mount as well.
Perfect for overlanding, camping, or just to add a bit of a safety margin to your fuel or water capacity.
I chose this because the Jeep JL tailgate is near its maximum weight capacity with an OEM 33” Rubicon spare tire and wheel mounted to it. Adding another 40 pounds of fuel there would have been problematic. This mount solves that problem by placing that weight between your front wheel well, and driver’s door.
7B53877A-DE08-48ED-A2E9-9A3C228FA8DB.jpeg501F6437-DFB9-48D6-882F-D2F9D63D4AC2.jpeg300C9728-2BDA-4CDF-9506-665B1E5E461D.jpegE4CE8DBA-9FCB-4482-BF29-2E89DEDCF287.jpeg72BE38CA-FC5E-47D2-94C4-10688780BEC0.jpeg7B53877A-DE08-48ED-A2E9-9A3C228FA8DB.jpeg7B53877A-DE08-48ED-A2E9-9A3C228FA8DB.jpeg501F6437-DFB9-48D6-882F-D2F9D63D4AC2.jpeg300C9728-2BDA-4CDF-9506-665B1E5E461D.jpegE4CE8DBA-9FCB-4482-BF29-2E89DEDCF287.jpeg72BE38CA-FC5E-47D2-94C4-10688780BEC0.jpegD7ECD96D-080E-46DB-85DC-3E8FC1D03EF1.jpeg6593E671-F75D-43D0-B971-843F7E3ECEE3.jpeg3D0F1AD8-FFEF-4239-9292-AE635E3D8A5F.jpeg1A94E0A6-3175-4D77-833C-3C2F8C39A7E7.jpeg
flipstick
