mercier@streetsmart.ca
Expedition Scout
SOLD Fully Equipped & Highly Capable Expedition Vehicle. Motivated to Sell to Build a New, Time Sensitive, Habitat Project With A/T Overland Equipment.
Vehicle Coming Back To US: I have a had a lot of interest from overlanders in the US, and will be showing the vehicle as I travel back from Calgary, Alberta to the Southwest US. Leaving early in October I plan to travel via Montana, Wyoming, Colorado, Utah, and Arizona before ending up in my JK's winter base in Las Vegas, Nevada. If I have not gotten back to you and your still interested, PM me with your location to see where we can meet.
Modified specifically for self-sufficient long distance overland travel in all types of conditions. Enhancement value: Suspension, Tires & Wheels: $20k - LS Engine & Trans Conversion $22k Axels, Diff. Housing & Drive Shafts $7k - Protective & Recovery $10k - Habitat Tent Flip-top, Camping Slide-outs, Hot Shower & Aux. Battery System 20k - See detailed list for breakdown.
Build started with Kilby Enterprise SEMA 2007 Jeep Wrangler Rubicon Unlimited and was followed by many enhancements to make it a highly capable and self-sufficient overland vehicle. Modifications total $85,000. We started with a Habitat flip-top tent hard top replacement that only adds only 190lbs. It sleeps four, although perfect for three, and that is why this dedicated expedition vehicle only has three seats. The rest of the space accommodates an electric fridge/freezer & propane stove slide-outs, 20.5 gallons of stored water, hot and cold tap/shower, A/T slide-out/pop-up storage cabinets, and tailgate drop-down table, 5 batteries (3 of which are small marine) & monitoring system. Front Corbeau BAJA reclining suspension heated seats. These plus factory air, crusie, tilt, pw, remote pl and navigation and satellite radio make the JK highly livable.
LS Crate Engine, 5.3 VVT & 6 speed automatic (20,000 miles ago), Terraflex Pre-runner long arm suspension & King reservoir shocks (38,000 miles ago), Factory Lockers & Disconnects, Superior Axles, Dynatrack ProRock 44 Housing with custom springs & drive shafts (21,000 miles ago), General Grabber 35 x 12.50 Tires (20,000 miles ago) on Jeep/Hutchinson beadlock rims. Complete Kilby undercarriage skid plate protection. Also underside, the ARB twin-air compressors with Kilby air tank & plumbing. Front equipped with Kilby recovery bumper, 12,000lb Warn winch & synthetic line while Poison Spyder Brawler Rockers protect the sides and the rear uses a AEV recovery bumper that holds 5 gallons of water and AEV synchronized tailgate swing-away to house a 10.2 gallon fuel caddy, Hi-Lift Jack, Pull-Pal winch anchor & full size shovel. Many more upgrades (see detail list).
The Kilby SEMA show vehicle was purchased at 23,000 miles and now has 73,500 miles, but all key components have been upgraded, most between 20,000 and 40,000 miles ago.
Professionally built and maintained as a dedicated Overland Frontier expedition scouting vehicle. Rather than pound my way through obstacles, I prefer finesse, because Overlanding is all about vehicle preservation. I'm out scouting a lot and as a result I'm alone 90% of the time, so having the best components that are kept in tip-top condition is very important. This vehicle has been field tested. Anytime something required improvement or adjustment to work harmoniously, it was done.
Normally I don't like worry about scratches because it takes the fun out of trail riding. But for the sale, vehicle just received a clear-coat to eliminate vehicle paint, tree branch, scratches picked up while on the trail.
OverlandFrontier.com
Contact Roger Mercier at 403.608.2354 or rogermercier@me.com.
21DSC_3016 by Overland Frontier, on Flickr
1_DSC6977 by overlandfrontier, on Flickr
2 IMG_0012 by overlandfrontier, on Flickr
3 DSC_4560 by overlandfrontier, on Flickr
4 DSC_8059 by overlandfrontier, on Flickr
5 IMG_0799 by overlandfrontier, on Flickr
14 DSC_4428 by overlandfrontier, on Flickr
BUILD PLATFORM - 2007 JEEP WRANGLER UNLIMITED RUBICON
Kilby SEMA Show Jeep Purchased w/23,000 Miles
- Rescue Green/ with top, hood & cowling in darker green two-tone paint
- Power Windows, Power Door Locks w/remote entry
- Cruise Control
- Factory Front & Rear Lockers and Sway Bar Disconnect
- Air Conditioning
- Factory Navigation, MyGig Stereo with Sirius Satellite, and Factory Subwoofer
LS CRATE ENGINE, TRANSMISSION & ALUMINUM RADIATOR
- New GM LS LC9 5.3 VVT (327 c.i.) Crate Engine @ 53,445 miles or 20,000 miles ago
- 320 hp, 325 torque versus 200 hp of stock 3.8 engine
- LS vs Hemi engine swap - all aluminum runs cooler & smaller block = more air flow
- Engine is only a few pound heavier than stock 3.8 six replaced
- Engine has AFM – drops to 4 cylinders while cruising
- New GM SL80 6 Speed Transmission (shifts so smooth)
- HD Aluminum double pass radiator designed specifically for LS Engine
- All work professionally done by MoTech Las Vegas $21,000
- Water wetter for extra cooling in radiator $39
- JK Heat reduction hood, paint & install $1,385
Sub Total: $22,424
SUSPENSION, TIRES & WHEELS
- Teraflex 2-4 Inch Pre-runner long arm suspension kit & speed bump stops with King Reservoir Shocks (Adjustable & rebuildable) installed @ 35,459 miles or 38,000 miles ago
- Custom made HD Coil Springs Front & Rear with custom made brackets
- General Grabber 35 x 12.50 R17 10PlyE Tires @ 53,128 miles or 20,000 miles ago
- Jeep/Hutchinson Beadlocks (Limited run w/Jeep style & logo for Mopar)
- Spyder Trax wheel spacers
- HD Tie Rod to Pitman Arm
- Ball Joint replacement @ 34,242 miles or 40,000 miles agoBrake Rotors – Front replaced 42,013 miles or 32,000 miles ago
- Brake Pads & Rotors - Front replaced 67,200 or 6,000 miles ago
- New Steering Box Tie Rod Ends & Drag Link Ends @ 44,796 miles or 29,000 miles ago
Sub Total: $19,995
BATTERY & MONITORING SYSTEM (FIVE BATTERIES)
Auxiliary Battery System for Fridge/Camping & Monitoring all 5 batteries
- 3 Valve regulated marine/RV AGM Deep Cycle Batteries (System works but batteries not holding a solid charge & need replaced)
- IBS Intelligent Dual battery system w/ low voltage disconnect
- Located in factory rear storage, now under A/T Stage 1 Drawer (see photos)
- Products & Professional Installation By Adventure Trailers
- 1 Odyssey (under hood) 1 Yellow Top Optima Battery (in AT Stage 2 Storage Unit)
Sub Total: $1,929
AXLES & DIFFERENTIAL HOUSING, & DRIVE SHAFTS
- Front Axle with Factory Locking Differential & Axel Disconnects
- 5.13 gears
- Superior Axles
- Riddler Diff Cover
- Rear Drive Shaft & Dana 44 with Factory Locking Differential
- 5.13 gears
- Superior Axles
- New Rear Driveshaft (52,265 Miles – 21,000 miles ago)
Front Housing & Drive Shaft
- Dynatrac ProRock 44 Unlimited for strength & ground clearance
- New Front Driveshaft w/ new Steering stabilizers (@52,265 miles 21,000 miles ago)
Sub Total $7,560
PROTECTIVE SKID PLATING & ROCKERS
Kilby 47" Front Bumper 500
Kilby Front Stinger
Kilby High Clearance Bumper Skid
Kilby Steering Stabilizer Relocation Bracket
Kilby Engine Skid
Kilby Belly Skid
Kilby Side Skids
Kilby Muffler Skid
Kilby Gas Tank Skid
Kilby Evap Relocater Kit
Kilby Rear Shock Skids
Back-up Light & Third Brake Light, Installed
Poison Spider JK 4DR Brawler Rockers, Powder Coated & Installed
Sub Total: $4,099
WINCH, RECOVERY EQUIPMENT & COMPRESSOR
Warn Winch 12,000 lb, installed w/license plate adapter-holder
Viking 3/8 – 125' Synthetic Winch Line & 250 Hawrse Fairlead, plus install
AEV Rear Bumper Synchronized Tailgate & Tire Carrier swing out, installed (Bumper holds 5 Gallons of water & Tire carrier holds full size shovel)
Hand-pump for rear bumper fluids tank
Pull Pall Winch Anchor, 11,000 lbs
Extreme Hi-Lift Jack
AEV Hi-Lift & Pull Pall Mount for bumper
AEV Auxiliary Fuel Caddy 10.2 Gallons
ARB Twin-Compressor with Custom made skid plate, installed
Kilby air tank, front & rear air line bibs, installed
(part of OnBoard Air System priced later)
Sub Total: $5,697
JK HABITAT FLIP TOP TENT (REPLACES FACTORY FREEDOM HARD TOP)
Less weight and lower center of gravity and much more room than roof top tent
Weights only 330 lbs (50 kg); replaces factory hard top so only 190 lbs (86 kg) more weight
Opens in 1 minute and closes/stores in under 5.
Footprint size of JK, unit can be moved while tent is deployed
Made of hand laid up fiberglass, carbon fiber & steel.
Waterproof tent made by NEMO is breathable, no fly needed
Sleeps four with 52 inches of headroom
7 foot standing height in hatch access from inside rear JK compartment,
Access is possible with ladder from two zippered screen doors
6 screened ‘no-see-um” windows
Window tint on camper top
Sub Total: 10,864
A/T LIGHTWEIGHT STORAGE CABINETS, FRIDGE & STOVE W/SLIDE OUTS
A/T Stage 1 Composite Drawer (fits behind 2/3 seat) LineX coated
A/T Stage 2 twin top-loading doors on Composite storage LineX coated (Replaces 2/3 seat)
Hot & Cold Shower, Nautic Junior Stainless Steel Heat Exchange Unit,
6 liters (1.32 Gallons) engine coolant heat exchange model
13.2 Flexible water tank (balder) under false floor of A/T Stage 2 storage unit
Aqua Jet 2.9 GPM, 41 PSI pressure cut out, sensing pump, 120v. 12 VDC
Switches, two shower heads & hoses, temperature control switch
(Total Water 20.52 Gallons = 4 Gallon Rotopacks, 5 Gallon AEV bumper,
10.2 Water Bladder & 1.32 Heat Exchange)
Tailgate Stainless Steel drop-down 25” x 13” table, with 14” bamboo slide-out cutting board
ARB Fridge Freezer & Insulating Blanket, – 50 Quart?
Partner Steel Two Burner Stove & removable windshield for stove
Twin Slide Out for Stove and Fridge, fits behind 1/3 seat & baside Stage 1 storage
Bracket for 5 lb Propane cylinder, clams to roll bar and Propane Tank
Anders external Cable Quick Connect for booster cables (Installed in lower front grill)
Products & Professional Installation by Adventure Trailers (A/T)
Sub Total: $7,164
INTERIOR UPGRADES & COMMUNICATION
Corbeau BAJA Reclining Suspension Front Heated Seats with JK brackets, installed.
Rugged Ridge Dash Organizer & Bar for GPS/Phone/Camera RAM Mounts
Rugged Ridge Front & Rear Floor Liners
Kilby Interior Rack
Kilby Radio Rack – Upper Counsel
Cobra Anniversary Special Edition CB Radio (Mounted on upper center Kilby radio rack
Kilby Rear Cargo Panels w/ 400W inverter, (2) 110V Outlets, (+110 with AT Stage 2)
(2) 12V Receptacles and rear video port
Two Rotopack 2. Gallon Water & Custom Mounting Bracket
(Total water 20.52 Gallons = 4 Gallon Rotopacks, 5 Gallon AEV bumper,
Sub Total: $2,506
ACCESSORIES NOT CURRENTLY INSTALLED (but come with vehicle)
Kilby OnBoard Air System (not installed except tank & 2 bibs- replaced w/electric system)
Premier Power Welder (not currently installed)
Golight Remote Control Lights (not currently installed)
Sub Total: $2,724
Total Improvement & Accessories: $85,962
SALE PRICE
2007 Wrangler JK Unlimited
- Black Book, Private Party in Excellent Condition $24,358
- Total Improvement & Accessories $85,962 less 60% Discount = $33,984
Asking Price $58,000 Canadian
$45,000 US This is a fair price, no low ball offers please.
Vehicle currently in Alberta, Canada and will be returning to winter base in Las Vegas, Nevada this fall.
But will deliver anywhere in USA or Canada - another Overland opportunity.
Corbeau BAJA reclining suspension and heated seats, add comfort.
15a DSC_3504 by overlandfrontier, on Flickr
Flip top made of hand laid up fiberglass, carbon fiber & steel. Waterproof tent made by NEMO is breathable, no fly needed. Sleeps four with 52 inches of headroom. Over 7 foot standing height in hatch access from inside rear JK compartment, great for dressing. Fold-up chairs can be used to sit up top.
15b IMG_0020 by overlandfrontier, on Flickr
15c IMG_0028 by overlandfrontier, on Flickr
Looking up into Habitat from interior access.
15d DSC_3510 by overlandfrontier, on Flickr
Looking down from Habitat interior access.
15e DSC_3513 by overlandfrontier, on Flickr
15f IMG_1347 by overlandfrontier, on Flickr
Hot & Cold Shower, Nautic Junior Stainless Steel Heat Exchange Unit, 6 liters (1.32 Gallons) engine coolant heat exchange model. 13.2 Flexible water tank (balder) under false floor of A/T Stage 2 storage unit. Aqua Jet 2.9 GPM, 41 PSI pressure cut out, sensing pump, 120v. 12 VDC Switches, two shower heads & hoses, temperature control switch
Total Water 20.52 Gallons = 10.2 Water Bladder & 1.32 in Heat Exchange unit, 4 Gallon Rotopacks, 5 Gallon AEV bumper.
3 DSC_3476 by overlandfrontier, on Flickr
Excellent storage for recovery wquipment. Note (top right) Filler access for 10.2 Water Bladder.
4 DSC_3487 by overlandfrontier, on Flickr
18 IMG_2223 by overlandfrontier, on Flickr
If you would like a canopy, Nemo makes one for the Habitat (below), but I'm keeping this one for next JK Habitat.
DSC_3668 by Overland Frontier, on Flickr
7_DSC7720 by overlandfrontier, on Flickr
8 DSC_0565 by overlandfrontier, on Flickr
10 DSC_2393 by overlandfrontier, on Flickr
11 IMG_0017 by overlandfrontier, on Flickr
11_DSC7165 by overlandfrontier, on Flickr
12 DSC_2858 by overlandfrontier, on Flickr
19 DSC_5548 by overlandfrontier, on Flickr
20 IMG_4879 by overlandfrontier, on Flickr
For 42 photos and detailed spec sheet with itemized price list to view on line or as downloadable pdf got to:
http://www.overlandfrontier.com/trek-legs/motivated-sell-120000-expedition-vehicle-45000-us
If you are interested, be quick. If I miss the opportunity window to build a new Habitat JK with AT Overland Equipment, I will be taking it off the market.
- Cruise Control
- Air Conditioning
Sub Total: $22,424
Sub Total: $19,995
Sub Total: $1,929
- 5.13 gears
- Superior Axles
- 5.13 gears
- Superior Axles
Sub Total $7,560
Kilby Front Stinger
Kilby Engine Skid
Kilby Belly Skid
Kilby Side Skids
Kilby Muffler Skid
Kilby Gas Tank Skid
Sub Total: $4,099
Sub Total: $5,697
Sub Total: 10,864
Sub Total: $7,164
Kilby Interior Rack
Sub Total: $2,506
Sub Total: $2,724
SALE PRICE
