Motorcycle and luggage tie down options
I'm compiling a list of items to start the build out of my E350. One of the things I'm having a hard time deciding is tie down points. Ideally Some kind of L track or something that I can flush mount into the flooring and walls. Price is of no concern. Quality and ease of use is my priority. Any advice would be great. Pics are very helpful. Also, is this the right section for this post? Kind of new here.
i resorted to BEDBOLTS for securing cargo on/in trailers
http://www.bedbolts.com
a really cool n simple to secure loads to the floor of the vehicle
simply drill a 5/8" dia hole in the floor drop the unit in secure w/ flat washer lock washer and nut
the unit is center drilled for common 3/8" forged eye bolts supplied in the kit
if you choose to install a ramp it can be fastened down w/ the eye bolt providing an attachment point for your ratchet tie downs
here is an old pic of the unit and one w/ eye bolt in place set in an old plywood decked cargo trlr
this is a bolt in/out set of rails that only required 4 bedbolts to secure
m:c 2-wheel chock 2.jpg
when the eye bolts are removed simpy plug the thru floor hoes w/ plugs provided in the kit
worked for me in my cargo and flatbed trailers
ELShockley
