MWO - Project "Ambo" 1991 F350
I agree, I wouldn't pull the idi to swap in a gasser. You'd be better off to swap vehicles than do that.
My Ambo weighed somewhere around 9400# I believe when I brought it home. Bone stock engine wise, with 4.10 gears and 235/85r16 rubber (for sale wouldntcha know). I don't have a tach but don't recall highway rpm at 65/70 being all that bad. Fuel mileage was 14-15 hand calculated driving it back to Ohio from somewhere-by-god Virginia.
By the time the 4x4 conversion was done she was pushing 10.5k and had become something of a slug, due in large part I'm sure to the 37/12.5/16.5 militaries. Besides being a huge jump in size they weigh about 188# each. A lot of tire wheel mass to get rolling.
New gears (4.88s) got her back rpm wise to about where it was with the old gears and tire/wheel combo, +/- 100 rpm depending on whose calculator you use.
Better but still a bit underpowered running all the extra weight and tire/wheel mass so a Hypermax kit was added. Finally starting to wake up and motor down the road with something approaching authority. Some tuning left to do, but it's much better than sans turbo.
Anyhow, a bit of info to chew over when contemplating your plan of attack and the affect doing certain things can have, such as weight added to do a 4x4 convert.
Just be glad you're working on a truck because I can tell you dinking around with the engine in a van must be one of the 7 levels of hell come to earth. :)
I have no interest in doing an engine swap. If I were to do a swap it'd be for a Powerstroke, but again no interest there. I've always wanted a diesel and now I have it :) I would love to get this weighed just to see what I'm working with. 9400lb isn't bad at all...I was expecting something closer to 14K to be honest. My Tundra is almost 8K and this feels extremely heavy compared to it.
Hardest thing for me right now is that fact that it's 2.5 hrs away at my parents. My HOA wont allow it to be parked in the driveway.....so, there's that. I have options for local storage, but have newborn coming in 7 weeks so we haven't checked them out yet.
Got the ambo out yesterday. We were able to get the OD shut off and stay off and the truck drove 100% better up and down the hills. Not really sure why it engaged again after shutting off last time. We were able to cruise up and down hills at 55mph without any issues.
The E4OD is a picky transmission, she wants everything to be perfect or she will throw a hissy fit. Often the issue is just a bad connection at some harness connectors, the one on the passenger side of the trans behind the small sheetmetal heat shield (make 100% sure that piece is still in place) being the #1 offender - disconnect, clean both halves of the connector, blow-dry with compressed air (use low pressure for the solenoid pack half), dielectric grease in the female pins to keep any moisture out, reconnect nice and tight, good to go.
If your tachometer ever drops to zero at idle, she won't like that either, new tach sensor is usually in order there.
Cheap LEDs in place of normal bulbs in the brake lines, that's another one that will mess with it, you can blame it on one of Ford's "better ideas" for the TCM programming. There are several revisions on said TCM programming, they pretty much all suck, some suck less than others.
Don't take me wrong, the E4OD can be a great transmission if it's built decently (early transmissions are NOT that, late ones and factory reman however are) and the factory TCM is tossed out the window and replaced with something aftermarket that actually makes sense in how it operates.
So, I have found a lead on a 2005 F350 dually rolling chassis. The guy will sell it to me for $2000. Includes the D60 front, D80 rear, and wheels/tires from the setup. Would this be worthwhile? I know @underdrive mentioned 2005+ setup and having a lots of pros (coils, stronger axles, etc). So far any donor OBS truck I'm finding is well above the $2k mark, at least here in Indiana.
Bobbyjr
