SAR_Squid79
I found a kick-butt deal on a 1990 FJ62 Land Cruiser here on ExPo. I brought her home a few weeks ago.
Here is the For Sale thread with some "before" pics: http://expeditionportal.com/forum/showthread.php?t=17178
She is a super clean Cruiser. The person I bought it from was technically the 2nd owner, but her parents were the original owners, and gave the truck her a few years back. It's never really been taken Off Road, and it's been a California car for pretty much its entire existance.
I took it, got it smog'd, registered, and washed and waxed! I didn't really like the wheels that came on it, and the tires were shot. ...So this weekend she got a little bit of a makeover, and got an OME 3" suspension lift, and new tires & wheels!
Well the install went pretty well. Like I said this Cruiser has always been a California car, so there was no rust, no corrosion, and all of the 20 year old nuts and bolts came off like butter. The only exception was the rear driver's-side spring pin. The pin that goes through the spring perch had to be cut out, but that was the only hiccup.
I guess the pin had bonded to the rubber bushings, and that S.O.B. wouldn't let go for anything. After pounding it with a hammer for about 2 straight hours, I decided to break out the grinder. 30 minutes and two 5" cutting wheels later, I was back on track.
I picked up the Ultimate Light / Medium 2" - 3" Lift Kit Part# ED60ULM from Kurt at Cruiser Outfitters.
The kit came with:
The install was very straight forward. At first I was confused by all the parts, and wanted to make sure I knew what went where . . . Once you get underneath the truck, you see that there's really only 1 way to install everything.
The new shoes are Toyo Open Country A/T's - size: 285/70/17 on 17" x 8" Toyota Sequoia alloys.
I took measurements before and after:
(All measurements are from the ground to the bottom edge of the fender)
More Pictures!
...It turns out that I need a little more room to clear the Tie Rod Ends, and I just ordered 2 sets of 1.5" wheel spacers from Marlin Crawler that should be here tomorrow. The truck was okay for the drive home from my shop, but at full lock the Tie Rod does contact the inside of the wheels. Also on the drive home I learned that I need an alignment BAD! I think I'm going to replace all the Tie Rod and Drag Link ends before I get an alignment. Taking a close look at them while I was installing the suspension, it looks like the linkage that's on there might still be all the original 1990 parts!!!
...Yeah, yeah - I know I need to clean all the blue junk off the tires!
The kit came with:
2 - CS003F Front OME Emu Dakar Leaf Springs - (NOT SIDE SPECIFIC)
[FONT=Arial,Helvetica][SIZE=-1]2 - N88 Front Nitrocharger Shock Absorber [/SIZE][/FONT]- (NOT SIDE SPECIFIC)
[FONT=Arial,Helvetica][SIZE=-1]1 - CS017R A Rear OME Emu Dakar Leaf Spring[/SIZE][/FONT] - (Driver)
1 - CS017R B Rear OME Emu Dakar Leaf Spring - (Passenger)
[FONT=Arial,Helvetica][SIZE=-1]2 - N94 Rear Nitrocharger Shock Absorber[/SIZE][/FONT] - (NOT SIDE SPECIFIC)
[FONT=Arial,Helvetica][SIZE=-1]4 - SB1 OME Poly Spring Bushing Kits[/SIZE][/FONT] - (NOT SIDE SPECIFIC)
[FONT=Arial,Helvetica][SIZE=-1]1 - OMEGS2 OME Greasable Front Shackle Kit (triangular)[/SIZE][/FONT] - (Front of Spring)
[FONT=Arial,Helvetica][SIZE=-1]1 - OMEGS1 OME Greasable Rear Shackle Kit[/SIZE][/FONT] (triangular) - (Rear of Spring)
[FONT=Arial,Helvetica][SIZE=-1]2 - OMEGP1 OME Greasable Pin Kit[/SIZE][/FONT] - (Front and Rear of Truck / Fixed (chassis) end of spring)
[FONT=Arial,Helvetica][SIZE=-1]1 - OMESD24 OME Steering Stabilizer[/SIZE][/FONT]
[FONT=Arial,Helvetica][SIZE=-1]4 - OMEU51 OME U-Bolts & Nuts - (Front - Square)[/SIZE][/FONT]
4 - OMEU59B OME U-Bolts & Nuts - (Rear - Round)
[FONT=Arial,Helvetica][SIZE=-1]1 - OME Center Bolt Spacer Kit[/SIZE][/FONT] - (Fit over rear leaf spring centering pins)[FONT=Arial,Helvetica][SIZE=-1]2 - N88 Front Nitrocharger Shock Absorber [/SIZE][/FONT]- (NOT SIDE SPECIFIC)
BEFORE:
AFTER:
More Pictures!
