Sharpie
I'm currently building my expedition trailer and am stuck on the issue with the axle, hub, drum, adapter and wheel. I am building an independent trailing arm setup with bags. I am going to purchase the #3500 spindle, hub and drum without the axle tube and plan on building the seperate tube sections myself. I am getting all of these from Southwest Wheel here in town. I am going to be running 2014 rubicon wheels and 30" tires. My questions are as follows:
- When it comes to mating a rubi wheel to a trailer hub what is the issue?
- I know alot of you guys run adapters but what for and how much farther do they make your wheels stick out from the hub?
- I have heard of hub centric and some other centric issues that you run into when doing this but how do you fix that issue or what can you do
instead?
- Is there another way of running rubi wheels with a trailer hub that does not require a $110 adapter/spacer?
- Am I doing something wrong or thinking into this too much?
I have looked at a lot of builds here but this issue just gets me. Sorry if this has been asked a lot but I have not been able to find anything on it. I would appreciate it if you guys running rubi wheels 5x5 on trailer hubs 5x5 could chime in. I need help and anything is useful, thanks. sharpie
instead?
