Need Advice: Electric Fan on Disco II
SpeedAgent
I'm shopping for an electric fan to replace my viscous fan. Has anyone here done this without sacrificing your fan shroud? If so, which fan did you go with and do you have any install notes you can share?
Regards,
Chris
aslostasyou
The best ones I've found are Flex-a-lite 210's. The should fit right in the radiator and you just put a piece of angel on the top and bottom to hold them in place.
I've done this mod on a couple Rovers with good luck. Wired up to a nice relay for each individual fan to the ignition with a momentary ground interupt that can be held down when going through water crossings.
Summit has the best price I think.
afirover
well said J
thier are some other brands out thier but wire as discribed by J it offerrs the best worry free set .....
AFI
aslostasyou
I would have broke the power but Afi suggested breaking the ground.....definately the way to go.
That guys a stud. :bowdown:
bdpkauai
