The IAC in my 96SR is probably the same as in your 95SR but you need to doublecheck that.
If it is then in my 96 FSM, it shows info on it on page 125 of the Circuit Diagrams Section in the Electrical manual (Volume 2 of the FSM).
It shows a coil located between pins 1 & 3 and pins 4 & 6. It also shows the wire colors for each of these pins so with some careful analysis, you should be able to decipher it. An ohmeter reading for each of those coils should neither be infinity nor 0 ohms. If it is, then that is likely a blown IAC motor.
