Been lurking for a while, finally poked my head up because I couldn't find this by searching. (maybe I'm just bad at it.)
I'm (hopefully) picking up a '10 Tacoma double cab 4x4 soon. I need this truck to be able to handle large rocks, dirt, snow, and mud, and roads with some really deep ruts. It's mostly going to be a daily driver, with occasional trips into southwest back-country and trips up mountain roads which are poorly plowed.
My "Stage 1" plan (as far as modifications to the truck) includes an ARB Bull bar, Warn winch, ARB compressor, F/R air lockers (I do most of my wheeling alone, getting stuck is not a good idea.) OME suspension, and tires. BFG KM2 seem to be popular, is this a good choice?
My main question is, given this kit,which claims a 2" lift with bullbar and winch attached, what's a good diameter to run without undue rubbing concerns, but with sufficient axle clearance. I want to stick with a narrow tire, for better tracking through snow and better traction in mud (so I've heard).
Also, I've heard that when the diffs are opened for lockers, it's a good time to install new ring gears to offset the difference in rolling radius of the tire.
lastly, tire sizes are width/sidewall width - wheel size, correct? I've had this paradigm from car tires, but wanted to make sure there wasn't a different one for trucks, which sounds kind of stupid now that I say it.
Sorry for all the questions, which probably seem pretty newbish, but I'm just trying to figure this out for my own since there aren't many people around here that do much more than 3' lifts and 30" wheels.
