Need some information F550
bjm206
Tom,
You have a lot of options with the F550 chassis cab (wheelbase and cab style). The link below has all of the relevant dimensions and options for Ford chassis cab trucks.
http://assets.forddirect.fordvehicl...eDoc_8801F25B-90F5-F0C2-D870-BF83D870BF83.pdf
Given your estimated box length you will probably need to use the 201" wheelbase. Your box manufacturer should be able to tell you what will be required for a given box configuration.
Tom, the only possible reason I can think of for using an F550 instead of a 13 or 18 ton Atego is the ability to easily disable DPF/urea injection systems for travel in 3rd world countries on high sulfur fuel and using high TBN oils. Otherwise I thoroughly second Joaquin's thoughts.
Charlie
Clemtiger84
