need some measurements
Nullifier
Ok I need the following measurments from pre 04 tacomas. this is for my up coming cab swap.
From a d-cab: from the front of the rear wheel well to the front of the bed. distance center to center of the bed frame mounts. the distance from the end of the frame to the center of the rear bed mount.
From a xcab. I need the distance between the body mounts for the cab section center to center. as well as the distance from the front body mount to where the frame starts to bend up toward the rear of the cab / start of the bed.
p1michaud
XCAB specs
Nullifier said:
Ok I need the following measurments from pre 04 tacomas. this is for my up coming cab swap....
Check your e-mail. I've sent you a file with some information that may help you. It was too big to post on here. It's all the XCAB specs.
Cheers,
P
Nullifier
Awesome that s exactly what I need. Now if I could get those same diagrams for the d-cabs I would be set.
Goldenbora
