Thanks @Lachstock . I've just taken my old steel tray off, and am ready to start building an ally one. Like you, I've done some websearching, and I see generally two kinds of "planks" for the trays (1) a 25mm deep 'ute' plank, and (2) a 40mm 'truck' plank. The ute-planks seem to have a starter-plank that you'd mount at the headboard and work your way back, bolting in from above as you go, whereas the truck-planks seem to have their tongue-and-grooves facing the other way (in relation to the starter plank and end plank)- so one would either have to (a) start from the back, working forwards if you are drilling/bolting from above; or (b) start from the front and work back, but then be unable to work from the top to drill, so you'd have to drill from underneath....spent a lot of time hunting down suppliers for different bits and pieces ...
$1000 approx for aluminium tray extrusions
Great question @GrantBerry, I would like to know the same. @Lachstock , was there anyone that was helpful when you used Action Aluminium in Queensland? I have called them twice and had a very unhelpful experience. I don't think I would have got an answer if I asked him for the time, let alone any details on the TRAY6TON products. I assume there was no one in Victoria that sell these products? Did the $1,000 you spent include shipping?Thanks @Lachstock . I've just taken my old steel tray off, and am ready to start building an ally one. Like you, I've done some websearching, and I see generally two kinds of "planks" for the trays (1) a 25mm deep 'ute' plank, and (2) a 40mm 'truck' plank. The ute-planks seem to have a starter-plank that you'd mount at the headboard and work your way back, bolting in from above as you go, whereas the truck-planks seem to have their tongue-and-grooves facing the other way (in relation to the starter plank and end plank)- so one would either have to (a) start from the back, working forwards if you are drilling/bolting from above; or (b) start from the front and work back, but then be unable to work from the top to drill, so you'd have to drill from underneath.
- So my question is two fold : (1) Which supplier and product did you use, and (2) did you fit/drill/bolt from the top, working backwards?
Thanks in advance for your advice.
Hi @Lachstock , thanks for your reply and photo's. Did you use the 40mm or 32mm deck planks?Hi gents,
Was really easy to do, and yep I started at the back and worked to the front (pic below).
I layed it all out on the back first to make sure the length was close to correct and made sure it all fitted up (pic below) and that all my subframe guestimates were close to correct!
View attachment 620654 View attachment 620655
There was a starter rail and and end rail which are different extrusions for the front and back.
I bought it from action aluminium in QLD and yep it was all the tray6ton parts, did it all via email and was quick and easy.
I just looked again and realised the shipping wasn't included in the $1000, total was around $1400 including shipping and was very quick and door to door.
'Looking good @Lachstock, nothing like working under the pressure of a fixed deadline to make things happen. Hope you make the ferry with all your list ticked off.So a few more activities been underway this last weeks, been flatout trying to organise everything with a 3rd of Jan deadline to be on the boat to Tasmania for a month!
The first MAJOR milestone is that it's finally registered, finally got the RWC completed with the new tray and all of the setup as it stands now. Very happy that's finally done!
I had the pop top lifters extended as well, I bought the off the shelf Jayco lifters and got them modified by a mate who's very handy with a tig welder.
They now lift to 800mm instead of the off the shelf 425mm, next steps was to build the pop top section but that hasn't gone as smoothly as I hoped..
Next job was to start building the pop top extrusion profiles onto the top, I had the lengths cut by a local fabrication shop but they missed ONE dimension by about 5mm .
This has thrown the whole process out, need to buy a new length and get it cut again. Below is the bottom frame before a test fit on the canopy.
And below is when seeing how it went on the profile on top of the canopy.... ever so close but not close enough!
Next was to put on the spare wheel carrier setup, which turned out really nice! I bought an off the shelf one from a mob called GSL, nice alloy work and went on easy.
Had to buy a length of allthread as the supplied bolts weren't suitable for the supersingles, and the retainer plate was smaller than the centre hole.
I used the under chassis spare chain lift connection and bolted that into the centre as the retainer which worked well.
Since the profiles were sitting on top, I decided to put the top extrsuions for the pop top on to see where it was going to sit heigh wise.
I do love when a rough plan comes together, and the height and look of it so far is exactly how I envisaged it!
Roofline will be just below the cab roofline, if I put some solar panels on the top it should be pretty much flush with the roofline!
View attachment 629851'
Next steps:
1. Get a new aluminium extrusion, get it cut then finish assembling the pop top to the canopy.
2. get a pop top sleeve made up between now and christmas! this is proving VERY difficult but have a few good leads to get it done.
3. electrical setup in the canopy, have a enerdrive DC2DC to charge a deep cycle AGM for the tassy trip. This will run lights and an engel on a drop slide.
4. Get the bed platform CNC cut out of formply and do a quick interior fitout for the first trip.
5. Get all of the water system finalised and the pump installed.. (probably won't get the hpt water scintex heat exchanger in for the first trip I think)
Simples..
Did you need to have a head board to get your tray approved? Or is it not required?
