NEW PRODUCT! Tepui Power Pack
Box Rocket
More innovation from Tepui Tents. Coming soon is the new Power Pack solar panel system.
http://tepuitents.com/pages/power-package
The Tepui Power Package is the first fully integrated solar solution for your Tepui roof top tent. Powered by Goal Zero, the Tepui Power Package allows you to charge your batteries while en route to your next destination. Featuring a built-in removable sleeve, the travel cover houses a Goal Zero Nomad 20 solar panel paired with a Venture 30 battery bank, providing up to 30 wH of charging power. The Tepui Power Package provides a cost effective solution for your power needs.
Goal Zero Nomad 20 Solar Panel
Rated Power: 20W
Open Circuit Voltage: 18-22V
Cell Type: Monocrystalline
Weight: 2.5 lbs (1.1 kg)
Dimensions (unfolded): 30.5 x 13 x 1 in (77.5 x 33 x 2.5 cm)
Dimensions (folded): 8.5 x 13 x 1 in (21.6 x 33 x 2.5 cm)
Certs: CE, FCC, ROHS
Optimal Operating Temp: 0-120 F (-17-48 C)
Goal Zero Venture 30 Recharger
Battery Capacity: 30Wh, 7800mAh (3.6V)
Power Output: USB (2x)
Weight: 8.8 oz (250g)
Recharge by: USB & Solar
Ideal for: Phones, Cameras, Tablets & more
Weather Rating: IPX6
•Built-In Micro USB Tip - Tangle-free charging for phones and tablets. Certified cables for efficient charging.
•Solar Ready™ - Built-in Charging Tip. No extra cables to lose. Charge up in 4 hours from USB - in 9 hours of full sun from the Nomad 7.
•Waterproof in Use - Dunk it, spray it, use it in the rain. Power that handles whatever Mother Nature can throw at you. No rubber plugs needed.
•30 Wh, 7,800mAh Power Pack - Power phones (2-3x), tablets (1x) and more. Lightweight and packable from the airport to the trail.
•High-speed USB 4.8A across dual ports - Two high-speed ports capable of dishing out the fastest charge possible, at the same time. Power two devices at once or share with a buddy. Integrated Flood Charge optimizes your charging time.
These will be available for the Kukenam/Autana models to start and larger panels/cover sleeves are an option that can be discussed if you have a different tent.
1Louder
There needs to be a sleeve on the actual tent. My batteries charge with my 7 pin connector while driving. Having a sleeve integrated into the tent would be useful.
Houie
