erin said:
Thanks Chris, that would be great, that is one part I need to figure out.
OK, here is a little pictorial of how I did it. I will show the procedure for the driver side. The passenger was similar but a little different.
Before pic - you can see the area that needs trimming.
The white sheetmetal sticking down in the previous pic is actually two "arms" that are pressed together at the ends. Each "arm" goes up at a different angle and ties into two places on the fender to provide rigidity to the 1/4 panel. In this pic, you can see where I cut the front-most piece with a dremel tool and peeled away the lower part below the cut.
This is a bad pic, but you can see the piece has been cut from the upper "arm" and the lower one is still attached to the fender well.
Now I notched the lower arm at a specific point so that it could be bent where the notch is.
Here you can see the notching
Using a small clamp to hold it in place, I bent the lower arm and raised it up so that it was matched with the upper arm right where I had cut it off flush with the 1/4 panel.
I drilled through the existing bolt hole in the 1/4 panel to go all the way through the lower arm where it was pressed in place. Then I bolted it all together, and cut the remainder of the lower arm flush with the 1/4 panel. I also trimmed the plastic liner with some tin snips or a hobby-knife, I can't recall which.
Here you can see the upper and lower arms and how they have been reworked (trimmed) but still tie into the fender well for strength.
Here is a shot of the pass. side. On this side, I don't recall, but I think I may have accidentally cut the lower arm too much (instead of a nice notch), so I just cut it off and then bolted it to the remaining arm, with the existing lower part (pre-drilled) up higher than it was before. Then I bent it in the same way to match up with the upper arm and so it would be flush with the 1/4 panel. All of the cuts and bolts were then painted. If you need more pics of how I did the pass. side, let me know.
