NL DC25 lithium wall charger
BlueVajra
I have a National Luna DC25 battery box with a lithium 100ah battery in there.
I charge it via alternator just fine, but not sure how to charge via the wall. Many of the chargers I see are for charging the battery directly, and very expensive.
Anything that I could use to plug directly into the batterybox? since it already has all the internals to charge correctly, I would think something simpler would be fine, but I am kind of clueless with this stuff.
Here is the battery box.
Buy the lithium battery charger of your choice and you could use those In/out Anderson connections on the battery box to connect the charger.
Most chargers are going to come with alligator clips or ring terminals so you’ll have to either find an adapter to the Anderson plugs or cut off the clips and wire in an Anderson connector yourself.
I personally just open my battery box and connect the charger directly to the battery terminals when I charge at home.
I believe that National Luna makes a plug to use when charging off of 110 at home. It plugs into the port in the photo.
Cheers
Bobbyjr
