Just looking to pick some brains here on the forum. My g/f and I were 2 hrs. from home this weekend for a wedding and we decided to camp the first night up there so we took the van and it ended up dying. I'm back home in the Boston area. Since I didn't have the tools or time to keep working on it, I had it towed to a garage this morning.
The van drove fine up there on Weds. and running errands up until Thurs. afternoon. That afternoon after a 1.5 hr. road trip, the airbag light flashed after restarting it; thought it was strange but it went out after a few flashes. The next morning after sleeping inside, I unlocked the side door manually (after locking the entire van with the remote) and stepped out to use the restroom. I closed the door behind me and I when I returned, the van was locked again with the keys inside. I thought maybe it was a security feature but I could not recreate the "self locking" so that should not have happened. I had a window open so I was able to get inside. After that, it took 2 attempts to start it but it started. It was very unusual; this van always starts on the first turn of the key. It ran fine for a mile and once I turned it off, I was never able to get it restarted. Considering the "strange" events immediately leading up to it being dead, I'm wondering if it is something with the computer.
It turns over strong. Starter and starting battery seem fine. Since it was easy to access, I tried replacing the crankshaft sensor - no change. I also checked the computer harnesses and EVERY single fuse - no luck. Even a shot of starter fluid didn't get it to sputter. Fuel, oil and battery conditions are fine. Spark plug wires and plugs are new within the last 1000 miles. Ignition switch was replaced last winter. Disconnected the battery to allow the computer to "reset" - no change. You can hear the fuel pump prime. No codes or check engine light appear. The spark seemed weak (checked for arc) and thought I should have been smelling more fuel for as many times as I tried to start it.
It's a mute point now but I'm trying to prepare myself for what it could be. Any similar experiences?
