No Start Fuel Issue
jdavis
Have been dealing with a no-start issue with my Gen II - '95 SR.
We were leading a trip up to go play in some snow when the engine just died and would not start. Ended pulling Monty to a safe spot and jumped into my girlfriend's built Land Cruiser. Enjoyed the day playing in the snow, then coasted my Monty down the hill to tar. Ran to town grabbed some MAF cleaner, pulled the MAF, cleaned, and put everything back together. Monty fired right up. So excitedly, we headed back to camp. The next morning Monty fired up and we headed home about 15 miles down the road the engine cut out again. Coasted to the site of the road, sat there cussing for a minute hit the ignition and Monty fired right up. Hit the Naches Tavern for beers and breakfast them made the rest of the 60ish miles drive home without incident. The next day Monty would not fire up and hasn't fired off for about three weeks until today.
Today, I applied 12v directly to the fuel pump. Let the pump run for a few seconds and hit the ignition...... guess what? Monty fired right up.
My long-winded question is.... what would cause the fuel pump not to activate when the ignition is on? Completely stumped on this one.
Thanks,
~ Jon
I would replace the fuel filter, pump, and relay, then take it on another short trip, bring a multimeter and see if the issue can be replicated. Would it crank and not start or not crank at all? Not a possible immobilizer issue? When it wouldn't start, did the check to see if there's pressure? Maybe add a fuel pressure gauge onto a line so you can quickly check.
jdavis
I finally tracked down the no start issue. Ended up being a broken wire. When I would put 12v into the fuel pump plug, the corresponding pin at the relay would read 3v. Started tracing the wire and found this - https://photos.app.goo.gl/fQnww7BuMjooW7zGA
The wire hanging down on the left goes to the fuel pump
frown
Thanks for the responses and support!!
jesus m anderson
