Martinjmpr
Wiffleball Batter
Curious about anyone who has a non-lifted (and not planning to be lifted) R50 and what size tires you're running.
Factory specs for my SE are 255/65/16 which is a 29.05" diameter tire. Right now the tires that are on it are Kumho Solus (AKA I'm pretty sure the cheapest tire you can get that can legally be called a "tire." If it was any cheaper they would have to call it a rubber band) in 235/70/16 which are the same diameter but almost .8" narrower.
I think it would look better (and ride better) with a wider tire but I'm wondering if it would be advisable to go up to a bigger diameter, too. Keep in mind my R50 won't be doing anything other than very mild off-roading (Forest Service roads and such) so I don't need a big MT or even an AT (most likely tire will be a Cooper Discoverer M+S. I had these on my '07 4runner and they seemed to love the snow!)
So what's the conventional wisdom on non-lifted R50 tires? Think I can get away with a 255/70 (30.06") or a 245/75 (30.5") tire?
