noob question about grips
leman
are grips interchangeable? i just got an xt225 serow tonight and it desperately needs new grips. can i use just any old grip?
TIA
The left and right side are typically different due to the throttle tube - but most grips are sold in pairs that take this into consideration, and most of the small bikes share common sizes. Both of my Hondas, the Suzuki, and the Husaberg all use the same size grips (the BMW is the only one that is different).
Not knowing what bars you have, it's impossible to say exactly what you need. But chances are that any decent bike shop will stock something that will fit. Just cut the old grips off and measure the OD of the bar on the left side, and the OD of the throttle tube on the right, then measure how wide the existing grips are. Then just match those measurements up to what is on the package at your local moto shop.
If you have heated grips (not likely on the XT225 - but like I said, it's impossible to say without seeing it), you may have a harder time finding grips.
thanks thats what i was thinking. most of the grips i find are "mx" grips and list they fit the TTR and YZ. but dont mention the XT or TW. they are only $12 so if they dont work ill just throw em up on ebay.
In addition this is about the best grip glue I have used, dries in seconds, and no need for safety wire.
leman, if you are running the stock bars, they are 7/8" bars.
Be sure to check out xt225.com, some good guys over there.
MOLLYmaz
