Off road lights
What off road lights are you running if any? and why? where are you mounting them? do you have any reccomendations for lights . I am thinking of going with a smal set of cube lights 2 spots on the bumper and 2 floods on the bumper. so idon't wan tto spend a bunch. budget and quality are king an dhopefully not mutally exclsuive. also wan low amp draw so looking at leds. Thanks in adavance
Beowulf
I am running two of the ARB LED intensity light. The build quality and light output is fantastic. They are mounted on my bumper one is a spot and one is a flood.
J!m
I was just looking at the intensity lights on the ARB site last night.
Good to hear they are performing well.
How is the reach on the spot (which I assume is a pencil beam)? I’m thinking two floods and two spots on the roof rack as well as two fog pattern on the bull bar (which may remain Hella 550’s)
I have four IPF super rally pencils up there now and they’ll pop popcorn at 100yards... need something that doesn’t make my alternator glow as brightly as the bulbs.
MOguy
I am running some cheap amazon ones also and they are working fine. I have a TJ and have them mounted where the stock "fog lights" were. I took one of those lights and mounted it on the back of my Jeep.
J!m
What do they actually draw?
I saw some knock-offs of the ARB ones today on eBay and it said 1100 watts? That’s like 10 amps at 12 volts. I’d need to run #12 wire!
Or are they saying the light output is similar to the astronomical wattage? Being eBay, it’s light on tech specs...
MOguy
I have no idea but I run 12 gauge or thicker on my accessories.
I went to Amazon and got the details.
They were 20-25 bucks.
Northpole Light 2 x 48W Waterproof Spot LED Light Bar Work Light, Jeep Off-road Light Bar, Driving Fog Light with Mounting Bracket for Off-road, Truck, Car, ATV, SUV, Jeep
D
Deleted member 9101
Guest
I use lights from ADVmonster on my bike and they are amazing. On my truck I have the cheapies off of Amazon and they also work great.
SoDakSooner
Cheap amazon 10" single row in my front bumper(for $60 it does a pretty good job). Sits just under the winch in the pic below. Just picked up a pair of the KC flex lights. No real purpose in mind yet but will probably mount to the A-pillar angled outwards for ditch lights.270_flexsingle_pairpack.jpgcolorado jeep.jpg
JeepinJon
It comes down to budget vs. expectations. I prefer the Baja Designs lights and have run their stealth bars in the past. I am waiting for the JT and then I will be getting the LP6/9 lights for that one.
If you want to save some money then Rigid/ARB is a good option. You give up some light distance, and a little less attractive beam patterns and options.
If you just want flood lights for setting up camp, or the look then the Chinese lights on Amazon are a good option.
Regardless there are options for everyone depending on what you want.
Marka1
