opinions wanted for my new van
Justaquestion
Hi there, I've been reading a bunch of forums lately with my new van project in mind, but thought I would ask people opinion on a couple of specific vehicles.
Here's what I'm looking to do: Get a van that I will be traveling in on very extended trips, to the point that I will be in all intensive purposes, living in it. So space is important (which is the main thing to rule out converting an Astro van). It also needs to be 4x4 or at least AWD as it will be in the snow during a lot of the winter time as well as some time in Baja off the paved areas. Some major trips it will be doing at some point in its life would be driving up and back to Alaska and to central america and maybe even further south from there. So it needs to be reliable (I'm fairly familiar with older motors and feel pretty confident in fixing most things myself). But then parts need to be readily available in various parts of this country as well as others. Fuel efficiency does matter somewhat simply because I am not wealthy and that stuff ain't cheap these days. BUT, I know you can't have it all, I just want to explain all the things I've been thinking when looking at vehicles. It would just be one or two people, the van build out and our gear. Never towing anything, so I don't need a ton of power.
At some point I would probably be putting a fiberglass high-top on whatever vehicle I end up going with, as well as a small "vanagon style" kitchen and eventually fully powered by solar.
some vehicles I've considered:
- I would prefer a diesel for many reasons, but might just not be that practical, financially, so keeping in mind the possibility of putting a cummins diesel in something someday down the road.
-I think the 7.3 e350's are great. But just way too expensive with a 4x4 conversion, so they are kinda out at this point.
-Astro vans are cheap, very inconspicuous, due to how common they are. Have AWD and are easy to put a little lift on them. Those 4.3 v6 motors are awesome, very long lasting, and anything GM is just so available to find. BUT, I just don't think there is enough space for our long term needs. So they are kinda out for now.
-I loved the idea of putting one of those little subaru ej22 motors in a Vanagon Syncro, but space inside is a little limited, and I don't have an extra 30k dollars for a van in mediocre condition.
-I looked at an old 1981 e150 with an inline 300 and top loader manual tranny with a 4x4 conversion by advanced four wheel drive systems. It has less than 150k miles total. I love that old motor. A timing gear, cast iron heads and bottom end. Virtually bullet proof, and gets better mpg than the heavier vans due to being only a half ton and having that inline 6. Plus, someday if it ever blew up, I could put a cummins 5.9 in it. The cons: While it should be a fairly easy to work on, Ford just isn't as easy to find any old part for as GM, cause everything on a GM is the same as almost every other GM.
-Also looking at a 1976 gmc 1 ton van with an unknown 4x4 conversion, with leaf springs all the way around. New crate 350 motor from GM and a rebuilt 205 transfer case (indestructible). I love how easy these are to fix and how easy parts are for anything on them (very important when traveling through mexico and southern countries). BUT, that 350 in a 1 ton is gonna get 14-15 mpg on the freeway if I'm lucky. I know it's not too popular to say, but I've always kinda liked how practical GM's were compared to fords as far as fixing and parts availability. I've never owned a 1 ton. is it going to be too heavy for loose dirt? I don't need the power of that.
So, my take on these two vans are: they both have pretty bomb proof motors. the Ford has a big advantage on fuel savings. the GMC would be cheaper and more easily available parts and fixing, and has a little bit of a start on the camper conversion already. Not a big deal, but it just probably makes it even a little cheaper then.
What do any of you think about these two vehicles? How about any other ideas that maybe I haven't thought of? or other possible arising problems or issues with these vehicles or travels that I maybe haven't thought of.
I welcome ALL opinions. My thoughts here are not fact, just what I believe from my past experiences with my vehicles. I am open to be convinced otherwise by a more knowledgeable person.
Thanks a bunch in advance. Sorry for such a long post, I just wanted to give all the info I could.
r_w
Both old vans will be able to get 95%+ of your normal repair parts from NAPA. Big unknown is the front axle and suspension on both--you need to figure out what the donor axle was to get parts and if any parts were custom. Some of the old conversions were downright SCARY on the highway so make sure it has good geometry.
Are you single? couple? small child or pet(s)? how long do you want to be out there before you need a restock?
I know I will fill any space I have, so I would get the smallest van to do the job. If I were single, I would get an AWD astro and not look back. Add a yakima box for a couple (and a good popup tent for campsites) and maybe a teardrop for a small family if a trailer works with your plans.
The ford will get good mileage if you keep it slow, but you can overload the springs, axles and BRAKES of the half-ton really easily. You have to keep it light.
Depending on the axle ratio the GM will be lucky to get double digit mileage, 15 is a pipedream IMO.
bdog1
Love 300 6. But 6 bt cummins in a half ton? No way. By the time "everything" is updated w/ HD stuff your frame will give up!
No mention of budget? How about all wheel drive chevy late model? There 1/2 ton. Prob. Good in snow I'm guessing? Reasonable mileage and all factory parts. Nothing cobbled together.
Plus, You sound like a GM guy.
I have an old E 350 7.3 diesel with a Q conversion so no axe to grind here.
I like things simple. My 4x4 (heavy)van gets 16 mpg if that helps. I also have a FI 300 6 also gets 16mpg. And it's 2wd and empty!
I really wanted extended top but have got over it now!
Sent from my weak AT&T iPhone
BajaSportsmobile
Baja Ironman
I can't imagine an AWD Astro van holding up to the punishment of the extended travel you are looking at. Get an '97 or newer E350 EB with a 5.4L Triton and you will be pleased with performance and fuel efficiency. Parts can be had anywhere and anyone can fix them.
mapper
Ive got an AWD Astro that started life, for the first 187k as a commercial delivery vehicle in Salt Lake City. It now sits at 215k and I take it all over the damn place including roads recommended for HC 4WD. It has a small lift and 235-70-16 tires, nothing more. The thing has lived a hard, hard life and sure, it is getting tired. However, the biggest repair it has needed in all those miles is a new CV at 195k and new ball joints at 205k both likely due to the torsion bar lift. I know the existing joints were original because they are partially attached with big steel rivets. Otherwise its had tune-ups, tires, brakes, oil changes (not necessarily frequently), shocks, and power lock actuators. There is no reason an Astro can't handle a big trip. Whether or not it can handle the severity of roads you elect to take is one thing but they are pretty solid machines.
mapper
At this age the van gets 15-17 mpgs on most trips with a large Thule box on top. I've had as much as 20 on stock tires and driving slow. City mileage, meaning city driving only, is about 13. Not exactly a fuel sipper but given the amount of space inside, not bad at all
java
I just picked up a V10 E350. I would have loved the diesel, but hard to find in what i was looking for. Mine is a RV conversion on the back, ie heavy. But i needed the room. PO said he averaged 10MPG no matter what, loaded empty, towing.
intothewild
Another vote for the AWD Astro. Once all the seats are out, there is a surprising amount of room. If you're rolling solo, there's no reason an Astro won't work for you. Parts are cheap, and everywhere. I get 18-20 MPG HWY, and average 14ish when doing mainly city driving. They are reliable, easy to work on. Easy to lift 4", can even make them legit 4wd, with T-Case swap. I have no lift on mine, and put 235/75/15s on, which are typically recommended for lifted astros. They fit mine fine, but are tight. They do great in the snow. It has done well off pavement. Obviously not a rock crawler, but nothing you pick will be.
There's tons of them for sale out there, go check a couple out and see what you think before ruling them out.
T.Low
Sounds like you realize the Astro question is not one of durability or reliability, its simply one of interior camping space: Do you want a smaller more nimble exterior dimension or a larger more spacious interior space?
As you stated, Space is a priority for you, so an Astro is probably out.
They are good durable reliable travelers, though.
friend of mine: http://www.expeditionportal.com/for...-through-Central-and-South-America-March-2012
Ask the guys at northwestoverland.org about my Astro; It goes the distance and beyond. Nothing rides as nice on FSRoads as Astro IFS. Voted "Most Likely to Brodie"-- Powerslides awesome and with the Locker combined with great throttle response and short wheel base it does excellent motorcycle style pivot turns for when the mtn road suddenly dead ends and ou have to turn around. And after 6 years of overlanding, I may finally need ball joints.
Reliable as a Swiss watch. Cheap to own and operate. Sporty and fun as hell to drive on and off pavement. I've smoked a couple $10,000 Suby converted Westys with the stock 4.3...just saying...
steelheadbum
May I ask what's your budget? Hard to answer your question not knowing how much we are dealing with.
Buck
The Redneck Mexican
2002 E350 7.3 PSD 4x4 8inch lift pop top conversion....
fireofficer001
