Flyfishjeep
Well I borrowed a friends OBD reader to see what the heck was the trouble code for the acceleration issue I was having (stand on it with RPM over 3500 or uphill here the jeep pushes it over 3500 and suddenly loss of power/acceleration until I coast it for a bit and then it resumes). It turns out this error code (P066dd) is relating to low oil pressure. I looked around on line and found this seems to be a problem for many, using the 3.6 Penstar. Have any of you had this issue for a newer JK and what was the ultimate fix. I have heard sensors bad, oil filter o ring is the wrong size, low oil pressure and a few others....any and all input is greatly appreciated.
