Pepe` Our Little Mule
James Pierce
It's Thanksgiving. The plan was to headed to Arkansas for 4 days of camping after dinner but I'm stuck at home sick. The head cold I've had since Sunday replaced the rich flavors of Thanksgiving dinner with a bland array of tastes ranging from sawdust stuffing to tofu turkey. I could have been eating Daisy's dog food for all the pleasure it gave me. With this unexpected time on my hands it seems perfect to begin the tale of Pepe` Our Little Mule.
Pepe` came to live with us in May of this year. I found him on a local Jeep forum. He was in pretty rough shape but the price was too good to pass up. I had been looking for a trailer project for a few months and this one fit the bill. Most of the rust resides in areas that I plan to modify so they will be cut out and replaced anyway. I've always liked the utilitarian look of the M101 CDN. I wish I would have been in the market when they were being decommission from the Canadian Military so I could have picked up a nicer one.
When I began looking for a trailer I started researching the forums for others who have them and found many good threads. I appreciate those who have taken the time to document and share their experience with the 101 and have enjoyed learning from them. My goals are not too different from theirs but my methods may be. It is hard to anticipate our needs and I realize as we begin using the trailer we will have a better understanding of what we really want.
Goals:
Be rugged while keeping the wight as low as possible
Have the ability to transverse rough terrain
Keep center of gravity as low as possible
Rack for our Eezi Awn
Water and fuel storage
Secure / lockable lid
Firewood storage
Pull out kitchen
On board propane
House batteries
Full size tires and spare to match Brandy's JK
When we got him home:
James Pierce
While I'm stuck inside I will try to bring you up to date. I promise there will be lots of pics.
First order of business was to flip Pepe over to refurbish the suspension.
For some reason a previous owner had switched out one of the backing plates. It has a hole for a wheel cylinder otherwise it is identical to the correct one on the other side.
James Pierce
Brakes have seen little use.
Incorrect backing plate will have to be "fixed".
Lots of PB Blaster.
No amount of PB Blaster was getting this one off.
Removing the spring bushings.
Bent landing gear will have to be repaired.
James Pierce
Correcting the incorrect backing plate.
Springs were disassembled sandblasted and then coated with POR 15 and Chassis Coat.
New "correct" bushings were sourced from Zenith Spring Co. and pressed in.
James Pierce
Brandy is becoming really proficient at running the blast cabinet.
Axel stripped and ready for POR 15.
Pressing the bushings into the spring hangers.
New spring hardware.
Axle and springs being assembled.
James Pierce
Brandy earning her keep.
I picked up some new 10" hubs with 5 on 5" pattern to match the JK so I could run the same tires and wheels. New wheel bearings and shocks go on too.
Completed Suspension.
Back Over.
New fenders will make the short list.
uk trailer guy
This is great to see. Talking as a saddo trailer type, I know that if your attention to detail runs this far to the running gear, which is the important bit but no one ever sees, then I can't wait to see how the rest of this build looks.
PS. Nice workshop :)
James Pierce
I had a local sheet metal shop brake up the lid.
Then I welded in the ends. I chose not to grind down the weld rather leave them exposed to match the utilitarian look of the trailer. None of the welds on the corners of the trailer are ground down so a spit polished lid would look out of place.
I wanted the lid to mimic the top of the trailer so I skip welded 1 1/4" tube steel around the bottom to match the top of the trailer.
I began working on a rack to support the tent. I was shooting for something that would resemble the Safety Devices rack found on the Defenders.
James Pierce
Thanks, I'm sure this comes as no surprise but I've been called anal ;) I am blessed with a small corner of my business where I get to unwind.
James Pierce
In an effort to duplicate the look of a Safety Devices rack I made some tube clamps identical to those used in their cages.
First I stamped out some flat bar stock and traced the template to it.
I then drilled the holes and used a jig I made in my tube notcher to cope the plates.
I stamped out the mating clamp and welded weld nuts to them. A step Safety Devices omits but eases the installation.
