ReluctantTraveler
I had two specific fabrication questions for @IdaSHO.
In the past, I think you mentioned that if you were going to do it all again today, you'd use a wooden frame instead of steel. Related to that (and how you've done your past fabrication)...
- If you properly scuff the plywood exterior, can you Monstaliner directly onto it, or do you need to put an epoxy sublayer first?
- How would you reinforce the areas where your jacks mount? Or would the wooden framing alone support that weight?
