Martinjmpr
Wiffleball Batter
This is purely an academic question but I know there are a lot of knowledgeable electric system gurus here so I thought I'd ask this:
I keep seeing ads on Expo for the Redarc DC-DC battery charger. Here's an amazon link, although I'm sure most of you have seen the ad on the forum:
I THINK I know what this is but I'm not 100% sure. So tell me if I've got this correctly:
Right now in my Suburban I have a dual battery setup with both batteries in the engine compartment (because the Suburban has a dedicated spot for a 2nd battery, as most modern GM vehicles do.) My "house" battery is connected with the - terminal going to a chassis ground and the + terminal going to an isolator that is, in turn, connected directly to the "starter" battery. Thus, when the engine is running the alternator charges the starter battery, power flows to the isolator, which is closed because the ignition is on and thus charges the "house" battery. When the ignition is off the isolator is "open" and thus the "house" battery will not discharge the "starter" battery when the ignition is off because the two batteries are not connected. So far so good, right? A basic "isolated dual battery" setup (my "house" battery is pretty much dedicated to the Truck Fridge and I don't use it for much of anything else except maybe occasionally to charge a phone.)
So let's say I have a vehicle that does not have space for a 2nd battery under the hood and I decide I want to run a "house" battery in, let's say, the bed of a pickup (appropriately sheltered, of course.) Certainly I COULD set it up the same way as my current setup is, with a direct connection from the House battery to an isolator and then from the isolator to the starter battery, but that might require me to run heavy 1 or 2AWG cable from the house battery to the isolator and then from the isolator to the starter battery - which is both difficult and expensive. But the cable needs to be 1 or 2AWG because of the immense amp load it's carrying. Depending on the size of the truck and the location of the starter battery, that could mean the necessity to run 10 - 15' of 1 or 2AWG cable.
Have I got all that right?
So if I'm understanding right, the REDARC DC-to-DC charger is a way of keeping a 2nd battery charged WITHOUT needing to have a direct connection to the main battery and/or a battery isolator, yes? So in theory, I would not need an isolator (because the batteries would not be directly connectord.) I would run a power cable from the starter battery to the bed of the truck, and then a much shorter heavy-gauge cable from the REDARC DC-DC battery charger to the battery.
EDITED TO ADD: And as a bonus the REDARC also seems to function as a charge controller so I should be able to hook a solar panel directly to the REDARC and it will regulate the charge to the battery without the need for a separate solar panel controller? Is that right?
So other than trying to understand the value of a DC-DC charger, my only other question would be: What gauge of wire would be needed to connect the REDARC DC-DC charger to the battery? Presumably it would not have to be the same 1 or 2AWG that I would need for a direct battery connection because it's not carrying that much power (I think the one I linked above is 40a max.) So what gauge would be needed? Isn't there some kind of chart or guideline that says "for X amps and Y length you need Z gauge of wire minimum?"
As I said above, I'm not contemplating doing this, I'm just trying to figure out how this would work.
Thanks in advance for any help!
Amazon.com: REDARC Electronics Dual Input 40A in-Vehicle DC Battery Charger : Electronics
Buy REDARC Electronics Dual Input 40A in-Vehicle DC Battery Charger: Battery Chargers - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
