keoni004
Good evening! I'm looking at purchasing a used 2013 Ram 4x4 1500 Hemi Laramie. I had an independent repurchase inspection, and I noticed these wet areas in the report. I'm completely new to trucks in general...and my only relevant experience is with my 1998 Land Rover Discovery that has OEM active corrosion prevention (leaks everywhere).
1. I think the red arrow is the oil pan drain, and I'm assuming that's normal.
2. I have no idea what the green arrow is pointing at but it looks wet behind the transmission - is that a big problem?
My mechanic was able to identify a small exhaust leak, so that's a huge relief. I'd like to know if these areas are concerning? Is there anywhere else that I should look at/
