Price Drop - ATLAS - 2001 GMC 2500 HD SAS’d w/custom aluminum flatbed 2016 4WC Grandby for Sale Colorado $50k
hobbsrt
ATLAS - 2001 GMC 2500 HD SAS’d w/custom aluminum flatbed 2016 4WC Grandby for Sale $72,650
Located just outside Denver, CO the rig started out as a 2001 GMC Sierra Crew Cab Long Bed 2500HD, 6.0L, 4L80e, Manual Shift NP263. A custom aluminum flatbed was added in 2018 by Anvil Rod & Customs with tons of storage, VLAIR air compressor and tank with remote chucks to fill tires, winterizing, etc. which also works great to balance the camper from side to side when camping. On top of the flatbed is a 2016 4WC Grandby flatbed pop up camper in really good condition with a few dings and scratches from being used.
The Truck
The truck is SAS’d with a CAD designed front suspension utilizing custom made arms that are of a radius arm design, it uses 3” Summit Machine uni-balls at the frame end and 1.5” Summit Machine joints where the upper arms meet the lower arms. The arms mount to ¼” thick skid plate that also doubles as the transmission/t-case mount. All the pieces were laser cut and bent. The fabrication is very nice, and most people don’t notice the truck has a solid front axle.
  • 2001 GMC Sierra Crew Cab Long Bed 2500HD, 6.0L, 4L80e, Manual Shift NP263, Manual front lockers
  • The front axle is out of a 2008 F-350 Super Duty (High Pinion Dana 60)
  • Heavy duty vented and slotted Power Stop calipers and pads
  • New differential bearings and 5.38 gears.
  • 37” ProComp MT2’s on 17” Walker Evans Street Lock Wheels
  • The front end also sports a complete PSC steering kit (http://www.pscmotorsports.com/vehic...4-cylinder-assist-kit-for-sas-conversion.html )
  • New pump, gear box, cooler/filter and hydro assist ram that is specifically built by PSC for SAS’d Chevy trucks,
  • Boss Double DIN media player jamming through the Rockford Fosgate speakers in the factory locations.
  • This suspension system uses all of the factory Ford steering linkages and panhard bar so parts are easy to get and inexpensive, everything uses off-the-shelf parts.
  • 2.5” Fox Factory Series remote reservoir shocks with 300# springs.
  • 173k miles and everything works as it should.
  • Factory disc braked 14-bolt rear end with new bearings and 5.38 gears as well with stock leaf springs and 2.5” blocks and an air suspension to level things out.
  • The truck sits very low for being on the massive 37” tires, it is less than 7’ to the top of the cab and right about 9’6” to the top of the camper.
  • Edge tuner was used to synchronize the increased tire size, odometer, and speedometer but not to tune the motor which you could easily do. It can also be used as a code fault finder.
  • A new supplemental dash was added to include remote winch control, light controls, outlets, gauges, air controls, a Boss Double DIN (including nav) and a Uniden CB radio.
The Flatbed.
  • VLAIR air compressor and tank with remote chucks to fill tires, winterizing, etc. which also works great to balance the camper from side to side.
  • The hitch was pushed back to accept a full size spare
  • 15-gallon auxiliary fuel tank with remote valve to fill motorbikes, ATV’s the main tank or whatever,
  • 4 good size boxes for storage and a super cool slide out drawer.
The Camper
On top of the flatbed is a 2016 4WC Grandby flatbed pop up camper in really good condition with a few dings and scratches from being used. We bought the camper used in VA (thanks Zach!). It had been used it for a one-year trip around the country with his wife and 1 year old son.
  • queen size bed,
  • 4-person dinette that converts to a full-size bed,
  • tons of storage,
  • 350 amps of solar (new) and 2-100AAH/12v batteries (2 years old),
  • refrigerator,
  • sink,
  • 2 burner stove,
  • propane heater,
  • 20 gals of water storage,
  • water heater (new),
  • indoor and outdoor shower,
  • fantastic vent.
  • Laveo dry toilet to get away from the blue goo and all its hassles – it works great and is so easy to use. We do have the cassette toilet if you prefer that.
  • Gas struts were added on the camper roof to make it easier to lift.
  • 4 manual lifts/legs to lift the camper off the truck and store it.
After it was all complete, I had it weighed and it came in right at 9400 lbs (not fully loaded) with 55% in the rear and 45% in the front. It tows a small trailer with motos or ATV’s well.
The truck has 173k+/- miles on it and everything functions and works the way it should with a few dings and scratches from being used as intended. There are no check engine lights on, almost all the factory exhaust has been retained (only the cross over pipe from the driver’s side has been changed to clear the driveshaft). Zero rust on this truck anywhere. A/C blows ice cold and the heat will make you sweat on those cold days. The interior of the truck came from GM with vinyl flooring for easy cleaning, manual windows with new regulators, and manual cloth seats all in great shape. I added some graphics which didn’t go on like I hoped, so they look better from a distance. It’s an easy fix for $30 and some patience (and less wind) putting them on (I took them off recently but they show in the pics). An Iron Bull steel front bumper was added with a 12,500lb warn winch with synthetic cable.
Everything has been well maintained and everything works, I have receipts for most stuff, a complete build sheet and cut sheets (excluding the flatbed), manuals, etc. for the entire rig. I wouldn’t hesitate to take this truck anywhere. It’s been through severe storms in Missouri, high winds in Kansas, camped in mid-teens weather and stayed toasty warm and dry. It’s great on the highway, county roads and offroad with the one of the best times being on the TAT where people were shocked that we were on the trail (it’s narrow in some places). We have used it mainly around the Rockies and driven it cross country a few times over the past five years but just aren’t using it as much as we had hoped because of life in general. It will be a great rig for someone who can use it more often.
You can see the the truck build here https://www.expeditionportal.com/fo...vehicle-platform-sasd-2001-gmc-2500hd.175097/ watch my conversion to an expedition vehicle here https://forum.expeditionportal.com/threads/2001-gmc-2500-hd-flatbed-camper-build.189196/ and here are a pics of the rig today https://www.dropbox.com/sh/czv43m86mg1hmuw/AACS4zqE69N2egRo1eP-q387a?dl=020230704_153108.jpg20230704_153122.jpg20230704_153231.jpg20230704_153326.jpg20230704_153456.jpg20230704_153503.jpg20230704_155220.jpg20230704_155250.jpg20230704_155745.jpg20230704_161203.jpg
Contact Rich at 303.594.4043 or hobbsrt123@gmail.com with any questions or for more information.
hobbsrt
Price drop to $50k. It's hard to know what to ask but have seen other similar rigs recently for sale in the $60k+ range so I thought I would try something a bit lower. We are just not using it like we thought only 1 trip this year for about 800 miles. Great rig!
hobbsrt
https://www.dropbox.com/home/Photos/ATLAS
try this link to the pics. Uploaded photos again here. Thanks for letting me know and for looking.
Bobah
