Ridgewalker
Help! I finally got the chance to install my DR coil overs. It was a rather easy install until I realized I had to lower it 1/2" so my roof rack wouldn't hit my garage entrance. This is when the problem occurred.
I jacked up the truck and loosened the set screw per instructions. Then I adjusted the passenger side fairly easily although there wasn't much room and it was fairly tight.
Next came the driver's side and the problems began
. I jacked it up; loosened the set screw; and started. No room to get the spanner wrench in without being cocked and hitting the threads. So I got out some rubber padding to protect it.
It was much harder to turn than the passenger side. I managed one full turn, but need more.
HELP! Is there a secret I cannot figure out? How do you turn the collar with no room and it is tight as all get out?
Thanks in advance.
Thanks in advance.
