huntsonora
:drool:
Only word that comes to mind is "awesome!". Can not wait until I am able to do mine this summer. It will first be with the sm465 and np205, but will soon follow with the nv4500 swap. Thanks Larry for all the great information and pictures and your time to post it all up for us.
Larry,
Do you do your own relearn and reset on the fuel trim? I'd love to be able to do that stuff, but I'd have to improve my computer skills considerably I'm sure.
Your install is clean and factory appearing, it should make the old burb zip right along.
My first drive in an 8.1 was an eye opener compared to a 454. Much zippier, so I can't imagine the RayLar cam making it run even stronger. Did you have to change your valve springs to accommodate the cam? Do the 8.1's run the bee hive valve springs?
It is odd how LS engines peak torque rpm's are so high, yet the cruise RPMs rarely exceed 2500.
The newer engines torque band is way too high as I see it.
To recap, my recollection is your running 35" tires, 4.11 gears and NV4500 trans with a .73 5th gear.
My guess is around 1900 to 2200 rpm at 70mph, sound about right?
Thanks for posting up, I am a big Suburban guy, so I love reading about your modifications.
Well done Larry. Well done.
:drool:
Thanks for the reply.
What rocker ratio is the 8.1?
Does it have aluminum heads?
I had a buddy years ago that had a 468 with a Sig Erson RV cam, that acted like a diesel. It would pull like crazy up to about 3500 or 4000 rpm and then fall right on its face!
That being said, with a cab over camper, trailer and a 6000 lb race truck it would run about 90 mph across the desert. :Wow1:
I would never consider doing anything that risky today, but 35 years ago our behavior was different.
We were young and dumb and there was way less traffic.
I know you are running the Dana 44 out of the old pickup, but if I was to run a Ford high pinion 44 and 241 down the drivers side could I run the stock Chevy push/pull steering using Chevy stuff knuckle out? I know I would lose the Ford dual piston front brakes, but I have not seen that they are any better than the 3/4 ton Chevy stuff.
I'm looking to get rid of a turbo 350/203 combo and replace it with a 700/241.
Since the drivers drop 241 are much easier to find I was thinking of that with the Ford HP Dana 44.
Not going with much lift so cross steer is out, plus I want to avoid a track bar. Keeping it simple.
I saw 2 NP241's passenger drops at the Pick-A-Part in Hesperia a few weeks ago.
I believe the 8.1L rocker ratio is 1.5 like all the older BBC.
Yeah, we all tend to take fewer chances as we get older that is for sure. I don't know enough about those Ford D44's to know for sure but it seems like you might be able to bolt on Chevy knuckles, spindles and hubs to make it work. I still think finding a passenger's side drop 241 would be an easier proposition. Heck, the passengers drop GM round pattern 205 would even be easier to find than messing with a front axle hodge podge. I agree, if I had a TH350/203 I would be anxious to get rid of it too. Oh, wait…I already did.When I first got my K10 back in 1996 it originally had a TH350/203. Good riddance!![]()
Has the weather been nice enough to take it on a shakedown run?
I am kind of interested in your impression of the new cam actually and see how you feel about the low range torque delivery with that cam. I know you said it had some real pop while driving down the road, it will be nice to see if it gives up much bottom end power and if the new found down the road power translates into better mileage (if you can discipline yourself enough to not romp on it!).
Do you plan on stopping at the Expo in Flagstaff this year?
Those things look awesome nose to nose Larry, What tire and rim packages are your running and are those warn hubs?
Let me just start by saying you cuz of u i want an 8.1 swap. I found a Kodiak parts truck but the motor runs on propane. Can i swap fuel rail and injectors and pcm ? or what do i have to do to make it run?
your work is impressive any help would be great. Your build is awsome
