dieselcruiserhead
16 Years on ExPo. Whoa!!
Photos from the build (unreal)...
I have a few months on the shaft as I am writing this. It doesn't vibrate at all. I wouldn't suggest going 100mph in 4wd but I feel very comfortable going 60 mph in 4hi. In all reality this truck is heavy enough and has a long enough wheelbase that I don't use 4wd over about 30mph in most cases.
I really like the fact that one spare 1410 u-joint will fit either the front or rear drive shaft at either the transfer case or the pinion. The slip yokes will also swap front to rear if I ever need to do that.
Ok, I think this gives a pretty good idea of the two pieces I want to add. I am having a Solidworks moment right now and cannnot get the 3D planes to work like I want.
http://i125.photobucket.com/albums/p60/Metcalfphoto/Dodge project/solid9.jpg
I think with these two plates added in this would be pretty strong. I could always run another plate to the main frame brackets.
I do worry about these 'buckets' collecting mud and water. Some drain holes are going to be in order I think.
Hopefully I can go to the junkyard this weekend and get another fuel door to french into the bedside for my aft auxiliary tank. I may try and use a Ramcharger fuel tank if I can find one ( and the 3 rear most crossmembers you need to install it ). I may also just build the tank so I can taper the back more and have clearance for my new exhaust.
Thats all for tonight....
