ryanmachus
Ok so I bought this 84 single cab pickup 3 years ago while in the Marine Corps stationed at Camp Lejeune, NC.
It was good to me as a mudding truck for a couple years and I certainly had fun with it.
This past winter I tore into it initially as just a restoration project. Redid the rear axle, rear disc swap, added a leaf to the rear pack, built flip kit, beefed up the rear end of the frame, grease-able shackle bolts. I pulled the cab off and pulled the tired old motor. Then I coated the entire frame with Por-15. Then I put a fresh built 22re in.
But then I started researching on here and got the itch to build a camper for it. My requirements were to keep it fully capable off road, yet have close to full amenities available. I have since decided due to time and money availability, that I will build it in multiple phases. I won't implement all I want until further down the road when resources permit. Mind you, this is all a learning experience and a very "build as you go" style project.
Bought a bunch of aluminum square tube:
Initial floor layout
It fits!
Wheel well arches added
Pulled the old windshield to fix some rust on the a pillar
It's not perfect but it will certainly do
Light coat of bondo
New windshield
Framing the walls
Pop top ceiling framed
The rear door framed
And that's where I'm at right now. I'll as some more pics later when I get them off my old phone
It fits!
Light coat of bondo
New windshield
Framing the walls
